SS Lancer
I just recieved this Jewel and need to remove galv nipple can I heat it up to aid with removal ?
Good ideaTake a hack saw blade & cut it from the inside. Go slow. You can do it.
Die grinder will work too
Ten 4Take pictures for us and post them.
Good job!
It doesn't matter how long procedure takes this intake is in exceptionally good condition and im privileged to own it for its vintage patina and will preserve itSo what if it takes 1 hr. No damage to your intake. Probably 3 cuts and it will come out in sections.
Galvanized isnt good for anythingWhen done, install a brass fitting, and it will never get stuck in there again. Brass and aluminum work better together.
In the plumbing industry dissimilar metals can cause problems .
