No compression-next move?
Big Block A body Tech
  1. RockinRobin
    RockinRobin Well-Known Member
    701
    190
    May 15, 2013
    Liberty Hill, Tx
    Local Time:
    4:34 AM
    Well damn. None of the local parts stores has a leakdown tester in stock. You have to buy it. I'll start by borrowing a compression tester just to confirm that mine isn't broken.
    • Like Like x 1
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      59,929
      31029
      Jun 7, 2010
      Georgia
      Local Time:
      5:34 AM
      Does this engine run? If it doesn't run, then your compression tester is probably correct.
    • Tooljunkie
      Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
      14,161
      13126
      Jul 22, 2017
      Manitoba
      Local Time:
      4:34 AM
      A spark plug smashed apart and an air fitting welded to it works too.
    • pishta
      pishta I know I'm right....
      16,963
      6614
      Oct 13, 2004
      Tustin, CA
      Local Time:
      2:34 AM
      They can drop valve seats holding up the valves, but zero across all? Are you sure the crank is turning? straight plug hemi could see the piston crowns down the hole, right?
    • Kendog 170
      Kendog 170 Let the boy go !
      850
      523
      Mar 10, 2016
      Tewksbury Ma.
      Local Time:
      5:34 AM
      My buddy'truck did the same thing idling in driveway. No compression,motor spun real fast with starter. Wish I could help but he sold the truck broken .
    • RockinRobin
      701
      190
      May 15, 2013
      Liberty Hill, Tx
      Local Time:
      4:34 AM
      UPDATE: Well here's a new one on me: The cam dowel pin is sheared off and the cam sprocket slipped about 70-80 degrees to the retard side. I think the dowel pin can be replaced, so I'll do that and see if it bent anything. It happened while it was idling, so maybe I dodged a bullet.
      • Like Like x 1
      • Tooljunkie
        14,161
        13126
        Jul 22, 2017
        Manitoba
        Local Time:
        4:34 AM
        That’s new. Glad you found it! That pin is going to be hard. And press fit. Need to find an old cam and see if it can be pulled out or driven out from the backside.
        Thats a new one for sure.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        18,086
        6359
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        4:34 AM
        Does the cam still turn?
      • jos51700
        jos51700 Well-Known Member
        5,224
        1916
        May 24, 2009
        Bel-Ray
        Local Time:
        4:34 AM
        If that dowel broke, then the cam BOLT is the problem.
      • RockinRobin
        701
        190
        May 15, 2013
        Liberty Hill, Tx
        Local Time:
        4:34 AM
        Yes, it slipped about 90 degrees and stayed in that spot.
      • RockinRobin
        701
        190
        May 15, 2013
        Liberty Hill, Tx
        Local Time:
        4:34 AM
        Agreed, I was told I didn't need to put thread locker on it, but I think I should have. It came off pretty easy.
        • Agree Agree x 1
        • PRH
          PRH Well-Known Member
          1,870
          2783
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          5:34 AM
          Exactly. The dowel pin is only there for alignment, it’s not meant to carry the load.
          If it sheared off...... the bolt was loose.
          • Like Like x 1
          • Agree Agree x 1
          • MobileCustoms
            MobileCustoms Well-Known Member
            1,698
            1595
            Oct 21, 2013
            Inver Grove Heights, MN
            Local Time:
            4:34 AM
            Glad you found the cause. Fingers crossed for you, for limited damage!
          • RockinRobin
            701
            190
            May 15, 2013
            Liberty Hill, Tx
            Local Time:
            4:34 AM
            UPDATE:
            Motor is out of the car.
            I have one of those hoses that lets you pump air into the cylinder to hold valves up while you change springs. I loosened all of the rocker arms so there is no pressure on the valves and shot air into each cylinder. All cylinders held pressure! Except for a little leaking past the rings into the crankcase which is normal. I think I may have dodged a bullet! I guess I need to fix the timing chain and do a compression test to see what I really have, but this is hopeful! Advice? Don't want to pull heads if I don't have to. New ARP head bolts cost a lot of $$$
            • Like Like x 1
            • PRH
              1,870
              2783
              Dec 14, 2018
              So. Burlington, Vt
              Local Time:
              5:34 AM
              I’m not a G3 guy..... but ARP head bolts for that application aren’t reusable?
            • RockinRobin
              701
              190
              May 15, 2013
              Liberty Hill, Tx
              Local Time:
              4:34 AM
              You're right. Just found out they can be re used!
            • 408 swinger
              408 swinger FABO Gold Member FABO Gold Member
              1,522
              1309
              Nov 12, 2010
              Iowa
              Local Time:
              4:34 AM
              I had the same thing happen with my son's Scamp. He took it up to the local station to fill. Calls me up, won't start. Pulled it home. Replaced cam and crank sensors. No start. For some crazy reason, I pull the cam sensor and take a peek inside. Looked like the tone ring was going back and forth(front to back). Pull the front cover. Spun the cam bolt out by hand. The gear was loose enough, that with the movement, the sensor didn't pick up. I now loc-tite all hemi cam bolts.
            • RockinRobin
              701
              190
              May 15, 2013
              Liberty Hill, Tx
              Local Time:
              4:34 AM
              UPDATE:
              Decided to pull the cam. There is enough general wear to justify replacement, so new cam, bearings, lifters are ordered.
              there are slight marks on the pistons/valves but they held air before I removed them. Tell me your opinion of the contact marks:
            • RustyRatRod
              59,929
              31029
              Jun 7, 2010
              Georgia
              Local Time:
              5:34 AM
              I don't know man. The only way to know for sure is to chuck them valves up in a valve grinder and see how true they are.......by the time you do that, you might as well do a valve job. Now's the time.
              • Agree Agree x 5
              • Bobzilla
                Bobzilla Well-Known Member
                729
                549
                Aug 10, 2017
                Livonia, Michigan
                Local Time:
                5:34 AM
                If it were me, I'd mock it all up again and measure valve to piston clearance to know how close they are. Kind of looks like it was kissing that piston for a while, although I could be way wrong on that.
                Either way, as RustRatRod said, must at least check those valves.
                No matter what, I'm so glad it did NOT have a catostophic failure with more damage. You dodged a big one this time.
                • Agree Agree x 1
                • mygasser
                  mygasser FABO Gold Member FABO Gold Member
                  410
                  196
                  Aug 17, 2010
                  faversham, kent. united kingdom
                  Local Time:
                  4:34 AM
                  lay the heads flat combustion chamber up and fill the chambers with kerosene or similar. if it doesn't leak past the valves you're golden :thumbsup:
                  neil.
                  • Agree Agree x 1
                  • RockinRobin
                    701
                    190
                    May 15, 2013
                    Liberty Hill, Tx
                    Local Time:
                    4:34 AM
                    Great idea, thanks!
                  • PRH
                    1,870
                    2783
                    Dec 14, 2018
                    So. Burlington, Vt
                    Local Time:
                    5:34 AM
                    Looks like fairly substantial contact to me.
                    I’m with RRR on this one...... pull em out and reface to be sure.
                  • mygasser
                    410
                    196
                    Aug 17, 2010
                    Local Time:
                    4:34 AM
                    contact or not if there's no leak with the above kerosene test then why? if there are bent valves they will leak, no question.
                    neil.
                    • Like Like x 1
                    • Agree Agree x 1
                    • RockinRobin
                      701
                      190
                      May 15, 2013
                      Liberty Hill, Tx
                      Local Time:
                      4:34 AM
                      I agree, but Machine shop explained to me why this is dangerous. Valves can be slightly bent, but spring pressure pulls them down flat to seal giving the impression that nothing is wrong. Need to confirm they aren't bent or they will eventually break. Off to the machine shop I go....
                      • Agree Agree x 2
