No compression-next move?
Big Block A body Tech
  1. RockinRobin
    RockinRobin Well-Known Member
    700
    189
    May 15, 2013
    Liberty Hill, Tx
    Local Time:
    12:52 PM
    If they are only slightly bent spring pressure can pull them back flat against the seats. I'm having them checked.
  2. mygasser
    mygasser FABO Gold Member FABO Gold Member
    401
    187
    Aug 17, 2010
    faversham, kent. united kingdom
    Local Time:
    12:52 PM
    if the car's a keeper it'll be best long term :thumbsup:
  3. RockinRobin
    700
    189
    May 15, 2013
    Liberty Hill, Tx
    Local Time:
    12:52 PM
    Just had new paint job, so yeah, it's a keeper.
    • Like Like x 1
    • RockinRobin
      700
      189
      May 15, 2013
      Liberty Hill, Tx
      Local Time:
      12:52 PM
      UPDATE: front cam bearing spun so cam journal and chain were not getting oiled. New cam/lifters/timing set. Oh and almost every valve was bent, they are toast.
      And if you think it couldn't get worse, we found a small crack in the block, so the block is toast. Now waiting on machine work to get done: valve job, tank and prep block from junkyard, check and polish crank, clearance new block for stroker crank.
    • my68barracuda
      my68barracuda Well-Known Member
      1,177
      865
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      1:52 PM
      Post # 50 # 51 mentions that valve spring pressure can pull slightly bent valves back flat against the seats.
      What? No way an closed valve with spring pressures in the xxx
      Ft Lb will pull a bent valve head / stem flat that has steel tensile strength in the xx,xxx Ft Lb.
      If there is wear in the valve guide, that may allow the stem to cock and the valve head to close. Even then the valve head will not be concentric with the heads valve seat.
      Not saying that I would not have them checked, I would get the valves chucked in a rotary spindle then lay an indicator on them. I am saying the reasoning given in posts 50 and 51 is B.S.
      • Agree Agree x 2
      • Like Like x 1
      • Bobzilla
        Bobzilla Well-Known Member
        724
        544
        Aug 10, 2017
        Livonia, Michigan
        Local Time:
        1:52 PM
        Where was the crack found in the block? Wondering if it was unrelated to the original issues.
      • RockinRobin
        700
        189
        May 15, 2013
        Liberty Hill, Tx
        Local Time:
        12:52 PM
        It was under the bearing in the front journal. Totally unrelated. Probably had more to do with it being drag raced and revved over 7000rpm constantly for 5+ years.
        It's probably fortunate that we found it when we did, a bare block cost me $210 dollars, the motor coming apart at 100mph plus and 7000rpm plus would have been much more costly!
      • yellow rose
        yellow rose Doctor of Thinkology.
        21,010
        17089
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        10:52 AM
        You put enough spring load on a valve and it will seal. Absolute fact.
        Had a customer bring in his heads for a freshen up. So I pulled a vacuum on them and they were sealed right up.
        When I took them apart, every intake was bent so bad you could set the valve on the bench and see the crooked stems. 5 exhaust valves were bent, but not that bad. All sealed up.
        I had him pull the short block and bring it in. He was a home assembler. He didn't have the cam times correctly AND he didn't measure piston to valve clearance. And that's what you get.
        So you can have a bent valve and have it seal. Seen it so many times I can't count it. So the solvent test, pulling vacuum on the port or using a flash light in the port only tells you it's sealed. Nothing else.
        • Agree Agree x 2
        • my68barracuda
          1,177
          865
          Dec 6, 2009
          Indianapolis IN
          Local Time:
          1:52 PM
          spring pressure with the valve closed is the attainable spring pressure at the installed height.
          Typically in the high 2 digits to low 3 digits Ft lb.
          Not enough to straighten a bent valve stem. But I agree, with a worn guide or a very slight bend in the stem, it would be possible for the stem bend to be contained within the guide diameter. That is why the stems need to be measured for straightness.
        • yellow rose
          21,010
          17089
          Jun 19, 2015
          Local Time:
          10:52 AM
          You don't need enough spring to make the valve straight. All you need is enough spring load to make the valve head conform to the seat. 100 pounds on the seat will seal a valve that is bent. Undercut stems, smaller than 3/8 stems all make it even easier to seal a bent valve.
        • RustyRatRod
          RustyRatRod Weenie idiot loser. FABO Gold Member
          59,634
          30670
          Jun 7, 2010
          Georgia
          Local Time:
          1:52 PM
          Who in the WORLD told you that? If you have a bent valve, YOU HAVE A BENT VALVE. Ain't no valve spring gonna pull it back straight. Ain't happenin.
        • RustyRatRod
          59,634
          30670
          Jun 7, 2010
          Georgia
          Local Time:
          1:52 PM
          That's total bullshit to be acceptable. Lemmie splain, Lucy. Even if you had enough spring pressure to pull a slightly bent valve to seal, what are you doing with it EVERY CYCLE? You're flexing it, that's what. There's going to be one side of the valve that hits the seat first, and then it gets pulled down tight. Do you see what's happening here? The valve head is flexing on the stem as it's being pulled closed by the spring. Over and over and over. You can kiss that valve goodbye in short order when the stem gets fatigue from flexing.
          • Agree Agree x 1
          • RustyRatRod
            59,634
            30670
            Jun 7, 2010
            Georgia
            Local Time:
            1:52 PM
            Total bullshit. You shouldn't be spreading this nonsense. It might make somebody cut a corner and cost them an entire engine.
          • mygasser
            401
            187
            Aug 17, 2010
            Local Time:
            12:52 PM
            i think he's actually telling us not to cut corners as a vacuum test can hide a bent valve so they should be stripped and checked. that's how i read it anyway. :thumbsup:
            neil.
            • Agree Agree x 1
            • fishmens67
              fishmens67 Well-Known Member
              7,293
              4542
              Nov 10, 2012
              idaho
              Local Time:
              12:52 PM
              Oh my O my. Bent valves will not seal unless the guide is totally wasted, even then I doubt it. lol
            • yellow rose
              21,010
              17089
              Jun 19, 2015
              Local Time:
              10:52 AM
              It's not bullshit rusty. Seen it many times. You don't think it be like it be but it is.
              I've never advocated for running bent valves. I'm telling you that a solvent test, or a light test, or a vacuum test may show the valve is sealed. You can still have a bent valve and have it seal.
              Happens all the time. Bent valves can seal. And do.
            • RustyRatRod
              59,634
              30670
              Jun 7, 2010
              Georgia
              Local Time:
              1:52 PM
              I'll put it like this. "I" will not run one "LIKE THAT". How's that?
              • Agree Agree x 1
              • fishmens67
                7,293
                4542
                Nov 10, 2012
                idaho
                Local Time:
                12:52 PM
                How are the guides ?
              • yellow rose
                21,010
                17089
                Jun 19, 2015
                Local Time:
                10:52 AM
                I'm not advocating running with bent valves either. Don't know where you got that.
                I'm saying I've seen it enough times to know just because someone brings in a head and says I did a solvent test and it passed doesn't mean the valves aren't bent. That's all I'm saying. Bent valves can seal. And do.
                • Agree Agree x 2
                • yellow rose
                  21,010
                  17089
                  Jun 19, 2015
                  Local Time:
                  10:52 AM
                  Had a 572 BBC come in for a surface. A couple of the valves just looked funny. So I pulled one. Bent. All 8 intakes bent. 4 exhausts bent.
                  Customer said I was just trying to sell him new valves! Found out later he didn't know how to degree a cam, hence the bent valves.
                  Also found out later when he brought in the short block that he had killed an externally balanced flywheel and replaced it with an internally balanced flywheel.
                  When the crank went up on the balancer it about shook me right out of the shop. I'm like WTF???? So I had him come by and see what was happening. He leaves and comes back an hour later with the original.
                  So I ask him..."dude...did it not shake like a dog shitting peach seeds?????"
                  Customer..."nope...smooooooooth as butter!!!!!"
                  Oh ok. 100 grams out and the engine didn't shake?
                  • Like Like x 1
                  • Agree Agree x 1
