My 67 resto mod Barracuda is not getting fuel. It wants to start with starter fluid / gas in the carb but won't run. Tomorrow I am going to make sure it has gas in the tank and check the fuel filter. IF it still won't start Id like ideas on what else to try.
I suspect it is the fuel pump but I'm not sure. How can I check and determine with certainty if that is the problem? I've had the car for 8 years and the fuel pump has gone out once or twice in the 8 years I've owned it. That seems like a lot to me.
I mention it is a resto mod as the electrical system seems to be the Achilles heel of this car. It looks great and makes a ton of power but I think whoever did the car cheaped out on the electrical harness. I replaced the alternator and regulator the last couple of years and when I go the car 8 years ago the firewall connectors were a mess.
One clue - last fall the car was intermittently hard to start. It would crank and crank and then catch with a roar.
Any ideas would be appreciated.
