NO more glass fuses
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
I bought a spade type fuse block this afternoon and rewired it after work. No more flickering lights.:cheers: It wasn't bad (no heater,no radio)
Napa part #785137
mounted it behind the kick panel.
congrats :cheers:
I haven't made it to this project yet, but it's on my list ( long list) of things to do.
Did you solder the female spades to the wires that connect to the box, or crimp?
Have you thought about an under hood relay station? I was out at the local yard this week and found a suitable donor, square body chrysler mini van has a relay block under the hood that has space for about 6-8 relays, and the block has removable clips that hold the wires in...
