Daves69
Mancini sells their chrome moly set under a 100.........
Mancini Racing
Mancini Racing
Never seen one....where would you get one?I sure would replace them all. You should get a pushrod length checker and find the optimal length. Inspect everything, including whether the springs go solid at full lift. SOMETHING caused that pushrod to bend. You should find that before reassembling.
Air up that cylinder through the plug whole with both valves closed. See if you have a leak, (bent valve).
This ⬆Did you loose a lifter. A friend just poked a pushrod through a rocker arm and the lifter came out of it'so bore and he lost oil pressure. Just a guess.
If it went up through the rocker it probably just jammed in the rocker and bent.When I took the valley pan off, the lifter was just sitting there. So if nothing else was damaged, that may have been the reason for the oil pressure. But now we're trying to find out what may have bent the rod in the first place.
If I over-revved the engine to the point it would break a rod, what's the likelihood it would only have damaged 1 and not all of them?
Pictures in a previous post show no hole in the rocker. I believe the OP said it was running and was not lead footing at the time. Probably fatigued from previous runs. If he bent the valve all he needs to do is pump air in the cylinder with both valves closed and listen for it coming out the intake port I would think.If it went up through the rocker.........
Ah I see. Well I agree with you, pressurize the cylinder and see what happens.Pictures in a previous post show no hole in the rocker. I believe the OP said it was running and was not lead footing at the time. Probably fatigued from previous runs. If he bent the valve all he needs to do is pump air in the cylinder with both valves closed and listen for it coming out the intake port I would think.
He hasn't indicated what cam or springs are in there.
I know this is an old thread but what engine size is this? I have this tread going below but just lost all my oil pressure suddenly. Stopped engine before damage I belief.
Check to see if you had a pushrod go through the rocket. I had it happen to .e twice with my old engine. Had the lifter pop out if the bore as a result and my oil pressure went to zero. Worth checking
383 intake gasket and valve cover choice
