No power to ignition coil
Nick Colangelo
New Member
Detroit, Mi
I have a 65 barracuda with a 225 slant 6 and I cant seem to get power to the ignition coil. I also can’t get the engine to turn over at the ignition switch. What seems odds is when I jump power directly from the battery to the ignition coil, the car will turn over fine and will get spark.
I’m not very good with electrical systems but it seems like it’s something obvious that I’m missing. The ballast resistor tested good as well as the coil. It seems as if power is not getting to the ignition switch or the ignition switch is bad. Let me know what you guys think.
