Norris Camshaft?!
Mopar General Discussions
  1. DentalDart
    DentalDart Well-Known Member
    1,615
    1088
    Jul 5, 2019
    Las Vegas
    Local Time:
    7:02 PM
    I got everything pulled apart, except I havent taken the heads off yet, those lower bolts under the headers are a B****.
    Pulled the camshaft out as far as I can, I need to take off the A/C condensor still, and here is my current cam- it's a Norris "D" 270H. It must be Super old because the only things i can find on norris camshafts are VW cams and they went out of business in 2008.
    Heres the only picture i can get with it still in the block, I'll take more when i get the A/C condensor out and the heads off. I'm really interested to see what pistons I have as well.
    • Like Like x 1
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      37,432
      9133
      Jun 21, 2005
      New York, on a Island
      Local Time:
      10:02 PM
      Go here Hot Rods - Norris cam history?
      and contact big Steve. He did have a phone number in about ‘08-‘10 ish area when Norris passes away. He has decoded a cam or two on “The H.A.M.B.” for a few people.
      Go here and contact 6pacmac Old Norris camshaft
      Same time frame. Old posts.
      The only thing I have noted is the advertised duration range spec is around 230@050 which equals roughly (according to Norris) in the 2O00-6000 or 300-6500 RPM range depending on the exact grind.
      THe Street series being smaller than the HP or race series. This should loosely apply to your cam. As we like to say here when a mystery cam comes up, tale out the degree equipment, it’s time to take a hard look at what the wheel says. Set up the dial indicator on the lobe or lifter and start turning the crank around.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • yellow rose
        yellow rose Doctor of Thinkology.
        20,449
        16522
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        7:02 PM
        Seems like a couple of years ago I called Norris about rockers and they said they may make some. I never checked back.
        Hopefully they aren't shut down. They make the best rockers.
        • Like Like x 2
        • krazykuda
          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
          51,761
          16413
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          9:02 PM
          I didn't know Chuck Norris made camshafts...
          • Like Like x 6
          • 70aarcuda
            70aarcuda Master Hoader of SBM FABO Gold Member
            15,132
            3521
            Jan 16, 2005
            las vegas
            Local Time:
            7:02 PM
            If the cam is still in the engine, we can check the lift and duration on it if the timing chain is still hooked up...if not ..oh well
          • DentalDart
            1,615
            1088
            Jul 5, 2019
            Las Vegas
            Local Time:
            7:02 PM
            I think it's a 2k-6k is pretty close to where my car would wake up.
            I was only able to find pages that showed Chevy and ford grinds which showed complete specs for a couple of norris cams.
          • DentalDart
            1,615
            1088
            Jul 5, 2019
            Las Vegas
            Local Time:
            7:02 PM
            I took those things off, have to be ready for when you come over. I dont want you waiting on my slow butt taking parts off lol
          • DentalDart
            1,615
            1088
            Jul 5, 2019
            Las Vegas
            Local Time:
            7:02 PM
          • TT5.9mag
            TT5.9mag Two atmospheres are better than one
            242
            247
            May 5, 2016
            So cal
            Local Time:
            7:02 PM
            67' Barracuda 273 (Camshaft Results at the Track)
            Look up this thread from a few years ago. There were two Norris camshafts tested and one was a 270.
            • Like Like x 1
            • Johnny Dart
              Johnny Dart Well-Known Member
              7,651
              1991
              Nov 30, 2006
              So Cal
              Local Time:
              7:02 PM
              Dam Bro, that car was already Cammed up !!!! :)
              • Demonracer
                Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                2,515
                650
                Jan 31, 2010
                Cleveland, Texas
                Local Time:
                9:02 PM
                I think these are the specs for the Norris cam you have. The cam I have has the same markings on the front of it, I hope this helps.
                Norris 270s specs are;
                RPM Range:1800-5800 Valve Lash:0.022 EX-IN Valve Timing:0.006 , Duration:270, Lobe Separation: 110, Duration @ .050" Lift:224-224, Intake Centerline:106, Valve Lift:0.468-0.468, Lobe Lift:0.313 , Valve Timing @ 0.006 Lift: Exhaust Closes 21 ATDC Opens 69 BBDC 106% Intake 29 Opens BTDC
                61 Closes ABDC
                • Like Like x 1
                • 70aarcuda
                  15,132
                  3521
                  Jan 16, 2005
                  las vegas
                  Local Time:
                  7:02 PM
                  your specs show a lash, his is hydraulic
                  • Like Like x 1
                  • Agree Agree x 1
                  • Demonracer
                    2,515
                    650
                    Jan 31, 2010
                    Cleveland, Texas
                    Local Time:
                    9:02 PM
                    Sorry I missed that, you are right mine was a solid lift Norris 270. I was just trying to be helpful.
                    • Like Like x 1
                    • DentalDart
                      1,615
                      1088
                      Jul 5, 2019
                      Las Vegas
                      Local Time:
                      7:02 PM
                      I read through that thread, the Norris was #5 and it seemed to perform pretty well!
                    • DentalDart
                      1,615
                      1088
                      Jul 5, 2019
                      Las Vegas
                      Local Time:
                      7:02 PM
                      Exciting right, maybe I need a bigger cam now.... lol.
                      • Agree Agree x 1
                      • Demonracer
                        2,515
                        650
                        Jan 31, 2010
                        Cleveland, Texas
                        Local Time:
                        9:02 PM
                        Just keep in mind, bigger is not always better when it comes to carbs & cams.
                        • Agree Agree x 3
                        • dano
                          dano Evil Handy Man
                          2,812
                          811
                          Aug 22, 2005
                          Gresham, Oregon
                          Local Time:
                          7:02 PM
                          It's all about the combo. Trans, Stall, Gears, Static compression, tire size, displacement, intended use, etc all enter the combo equation.
                          You're in good hands with 70aarcuda.
                          • Agree Agree x 1
                          • DentalDart
                            1,615
                            1088
                            Jul 5, 2019
                            Las Vegas
                            Local Time:
                            7:02 PM
                            You know when bigger is always better? With chocolate chip pancakes. :)
                            • Like Like x 1
                            • dano
                              dano Evil Handy Man
                              2,812
                              811
                              Aug 22, 2005
                              Gresham, Oregon
                              Local Time:
                              7:02 PM
                              I'm more of a waffle guy but I've made a few of those for my boys!
                              • Like Like x 1
                              • DentalDart
                                1,615
                                1088
                                Jul 5, 2019
                                Las Vegas
                                Local Time:
                                7:02 PM
                                I am too, that's what I made this morning.
                                • Like Like x 1
                                • toolmanmike
                                  toolmanmike FABO Staff Staff Member FABO Gold Member
                                  46,894
                                  31167
                                  Jan 18, 2006
                                  Iowa
                                  Local Time:
                                  9:02 PM
                                  Norris cam, Rhoads lifters?
                                • DentalDart
                                  1,615
                                  1088
                                  Jul 5, 2019
                                  Las Vegas
                                  Local Time:
                                  7:02 PM
                                  What's Rhoads lifters?
                                • toolmanmike
                                  46,894
                                  31167
                                  Jan 18, 2006
                                  Iowa
                                  Local Time:
                                  9:02 PM
                                  They bleed down at idle. It takes the roughness out of the cam at idle and low rpm.
                                • DentalDart
                                  1,615
                                  1088
                                  Jul 5, 2019
                                  Las Vegas
                                  Local Time:
                                  7:02 PM
                                  This is what I have. I think they are stock?
                                • rumblefish360
                                  37,432
                                  9133
                                  Jun 21, 2005
                                  Local Time:
                                  10:02 PM
                                  Yup, there stock.
                                  Read here about the variable duration lifters. Some people do not like there tick. It doesn’t bother me personally.
                                  Rhoads Lifters
                                  • Like Like x 3
                                  • DentalDart
                                    1,615
                                    1088
                                    Jul 5, 2019
                                    Las Vegas
                                    Local Time:
                                    7:02 PM
                                    As long as it goes fast and sounds mean I'm a happy camper. @70aarcuda was showing me videos of his race cars, when I told my wife about this and that our daughter would love to race cars my wife replied "dont get any ideas."
                                    .... To Late!
