I posted this on the truck forum also. What are the torque specs and procedure for adjusting the bands on a 96 Dakota 2 wd. with a 3.9? I find conflicting info on the net and don't have a manual. Thanks, toolman
front band...back off jam nut...tighten adjuster to 72 inch pounds or snug ...back off 2 turns...tighten jam num
rear band...drop pan...back off jam nut...tighten adjuster to 72 inch pounds or snug ...back off 2 turns...tighten jam num
I just did my 1965 904 tranny 2 days ago. The factory manual said to back off 5.25 turns for the 904 and less (~2.5, forgot) for 727. I don't think it is super-critical and kind of hard to measure the 72 in-lb snug. The idea is to make it loose enough to release fully, similar to adjusting drum brakes. I would say if your band link fell out it was real loose or the band totally worn since I had to back it way off to get the link out in a 413 torqueflite (fwd version of 904). For some torqueflites there is an improved thicker band link plus other cheap upgrades (L/R piston that doesn't ****), so maybe google.
fishy68,
Thanks for that info on the "double wrapped" rear band. First I heard of that. I wondered why 5.25 turns since I recalled backing off 2.5 turns on other torqueflites. Makes perfect sense. Too bad I already bolted the pan back, so can't look at the band now.
I knew the question was a 96 Dakota, but I thought similar to traditional Torqueflites. If a 3 speed hydraulic, I bet it is very similar. What is the model number of the tranny? I thought Mopar went to solenoid controlled shifting in the 4 speed "electronic" transmissions, at least judging from the 80's - 00's Mopars I have owned.
