tcanin00
As implied, I'm having problems going from OBD I to OBD II. My car is a 1970 Dart Swinger and it has a 5.2 and complete harness from a 1994 Dakota. I have an engine harness, PDC, and ECM from a 1999 Dakota that had a 5.2 and a manual transmission. I cut the C1-3 connectors off the harness and spliced them at the 60 pin OBD I connector. I made sure to go through the schematics, take notes, and check off each wire as I soldered them.
When I was done with that, I tried to start car and nothing. The fuel pump primes, it cranks, but doesn't start. I double checked the connections and made sure the computer was grounded.
I have read that higher trim levels of trucks had a central time module that operates the security system. If the ECM was ever connected over the CAN/BUS network to the CTM module, it will continue to look it. I read that if that is the case, the network wires can be shorted together and trick the ECM into thinking there is a problem with the network and ignore it. I tried that, and it made no difference.
Picture of engine in question. I recently moved the battery to the trunk, and plan on moving the washer reservoir and PDC to where the battery was.
