[SOLD] OEM 1966 to 1969 Automatic Transmission Crossmember
68HemiRR
Winona, Minnesota
This is a OEM 1966 to 1969 Automatic Transmission Crossmember.
It is in good condition, just needs a clean up. I believe it
will also work on 1970-up 4-speed transmissions with tailshaft
casting numbers C99539 and C99621, and possibly other years and
models as well. $60.00 OBO. Local pickup, or buyer pays shipping.
I think you’ll find that the spacings to bolt it to the torsion bar crossmember are wider apart on one side for the 66 (and earlier years). I used a 67-72 and modified the trans mounting to fit a 42RH and also had to redrill one mounting hole IIRC on the driver’s side to fit the T bar crossmember
