oh f*%k
Discussion in 'Big Block A body Tech' started by 70wayfarer, Aug 9, 2018 at 2:46 AM.
  1. 70wayfarer
    70wayfarer Well-Known Member
    406
    24
    Jul 20, 2011
    new zealand
    Local Time:
    5:27 PM
    getting right into assembling the 493. went to screw the 1/2" oil pick up in to find the engine builder had forgotten to enlarge the hole. short of disassembling the block to do this what are the alternatives. i'm using the melling hv pump. i have been looking at external pick ups like the milodon systems. the 21001 requires a longer shaft. this is a street strip 493. will be spinning to 7000. thumbnail.jpg thumbnail (1).jpg
  2. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,425
    385
    May 1, 2011
    Netherlands
    Local Time:
    7:27 AM
    Put a stock pickup in it and rev to 6000 instead of 7k.
    I doubt there's much reason to push the rpm-limits with a 'fun' engine.
    Enlarging the block's pickup thread usually means the hole has to be offset drilled and tapped to prevent breakage at the block.
    Unless you have remote pickup like you show in the photo, then it's just an oilpan mod.
    • Like Like x 1
    • vitamindart
      vitamindart Well-Known Member
      969
      96
      Jun 11, 2010
      Vernon,Wisconsin
      Local Time:
      12:27 AM
      go external with a single line and never look back. I did using a different cover and a swinging pick up.
      saw a few blocks messed up by someone not skilled tapping that pick-up to 1/2"
      • Like Like x 1
      • Agree Agree x 1
      • IQ52
        IQ52 Well-Known Member
        2,148
        1246
        Jul 30, 2011
        Idaho
        Local Time:
        11:27 PM
        Use the 3/8" pickup. I've run a 3/8" on my 850 HP 500" engine spinning it to 7,200 rpm.
        • Like Like x 2
        • Bulldozer
          Bulldozer Well-Known Member
          15,430
          1530
          Oct 16, 2011
          Down the road
          Local Time:
          12:27 AM
          'zactly
        • 70wayfarer
          406
          24
          Jul 20, 2011
          new zealand
          Local Time:
          5:27 PM
          years ago i ran a 383 with 3/8 pickup to 7500 for 350 1/4 mile passes with no problems. the 493 is a bit more serious of a build and don't want the engine so don't mind going to a external line.
        • brian6pac
          brian6pac Well-Known Member
          2,435
          1105
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          1:27 AM
          I used the same pick up but a different plate on a 495, It's newer from Milodon
          uses the stock length shaft and moves the filter up higher and it is all one piece.
          I cut the hose shorter so it didn't have that tight of turn on the final assembly
          • Like Like x 4
          • 70wayfarer
            406
            24
            Jul 20, 2011
            new zealand
            Local Time:
            5:27 PM
            Looks tidy to. What is the part number for that
          • brian6pac
            2,435
            1105
            Nov 15, 2016
            N.E.Ohio
            Local Time:
            1:27 AM
            • Thanks! Thanks! x 1
            • twayne24365
              twayne24365 Well-Known Member
              1,458
              270
              Jun 18, 2013
              Maryland
              Local Time:
              12:27 AM
              The external setup is nice, I’ll agree with the stock 3/8 pickup would be fine tho
            • IQ52
              2,148
              1246
              Jul 30, 2011
              Idaho
              Local Time:
              11:27 PM
              Well then just do it! Why bother to ask?
            • 70wayfarer
              406
              24
              Jul 20, 2011
              new zealand
              Local Time:
              5:27 PM
              assumption is the mother of all fuck ups.
            • Jim Lusk
              Jim Lusk Well-Known Member
              3,773
              266
              Mar 8, 2006
              Fresno, CA
              View My Photos
              Local Time:
              10:27 PM
              Are you running a motor plate? The external pickup looks like it might interfere with stock motor mounts.
            • 70wayfarer
              406
              24
              Jul 20, 2011
              new zealand
              Local Time:
              5:27 PM
              yes, running a plate. ordered the 21010 from summit. cheers
            • brian6pac
              2,435
              1105
              Nov 15, 2016
              N.E.Ohio
              Local Time:
              1:27 AM
              Great, you will like it!
