Oil change tools.
JoeSBP
RLTW!
NC
This may be a fairly weak post, but it is a straighforward RFI. I need some quality oil change stuff. I am tired of dikn around with the cheap plastic stuff that leaks everywhere. I like the deep open galvanized pans(and have a few), but hate having to clean them out.
Basically I'm looking for a cross between the cheap drain pan/oil container combo, but made out of galvanized steel like the pans. I have a 3gal bucket with a pour spout top I use to hold it until I go dump it. In my diesel it was cake since the bucket fit under the truck. Just trying to make my life easier. I know there are some other crafty and lazy types on this site as well, whats your set up?
what if you line your galvanized pan with a cheap plastic tub? Those jerry can looking oil collection containers are given away free out here at carnivals and fairs from the waste management district. Usually a van full of them, every guy seems to have one on the way out.
Funny you mention that. I was bitchn last week while cleaning one out, and the old lady said," you should just cover them with a crock pot liner"...
a Jerry can style one is exactly what I want. Easy to wipe off, pour oil out, then seal it up and stick it in the corner.
something like this..but this not the free design.
or the big boy 12.5 qt size.
I have one similar. Love it.Lots of capacity and a built in spout to pour into a waste oil container. I think Mac Tools still has them.
Those are the type I hate. They drool oil. Was thinking maybe a steel jerry can with a 55gal drum bung welded into it's side, then a large galvanized funnel with a bung cap welded to the base. Screw funnel on, drain oil, screw funnel off, cap with standard bung cap.
Something just like this, but modify it to take a funnel on it's side and seal back up. I think a 55gal drum bung would work well. They aren't cheap, but I'm past the point in my life of pinching pennies. I would rather spend the cash, and make it the last time I'm buying that particular thing.
Do you have a hoist?
Nah I just use a floor jack and stands
I have been using that type for years, and never a drool, LOL. After oil is drained I put the plug in, and wipe the tub out a bit with a couple paper towels.
When it's full I drain it into a 40 gallon jug and give it to a guy that heats his massive shop with a used oil furnace.
which one do you use? I have never found a plastic one that didn't leak
Too bad, The one I have is probably 10+ years old. Works perfect. I sold them when I was a Mac Dealer. Where did you buy yours at?
Agreed, but I have yet to find anything quality
I have the one with the yellow screw on funnel. Used it for at least 15 years. Not my favorite.
Also use a 30”x30”4”deep pan. Believe it was from a bakery.
They catch all the drips, and i pour it off the corner and clean it by rubbing sawdust around inside.
Great for cleaning parts in too.
I had a leaker in the trunk of my Diamante, tossed the entire trunk mat and it still stunk like a differential, I cant imagine what the dealer did with that car in trade once they found that out! I know, they sent it to auction and made 2X what they gave me for it. My cap actually split, maybe I tightened it too far or it broke down..
