Oil explosions when revving engine
Small Block Mopar Engine
  1. NorthernSwede
    NorthernSwede Well-Known Member
    231
    0
    Sep 12, 2009
    Luleå, Sweden
    Local Time:
    10:55 AM
    Hi all!
    i have a strange problem in a friends car, it's a '68 Dart with a 318 of unknown origins and a 904, what happens is that when revving the engine high for example when burning tires there suddenly comes a great cloud of smoke from the engine compartment and when one opens the hood the entire engine compartment is filled with engine oil like someone dropped an oilbomb under the hood though the engine doesn't leak during regular driving or when standing still so the question is what might the problem be?
  2. abodyjoe
    abodyjoe Well-Known Member
    22,755
    10072
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    4:55 AM
    sounds like excessive crank case pressure. blow by, crank case not vented properly?
  3. magnumdart
    magnumdart There is a bad moon on the rise.
    3,784
    1320
    Dec 21, 2006
    Rogers, Arkansas
    Local Time:
    3:55 AM
    Put on your goggles, open the hood and rev it up. You might be able to see where it comes from. I once had a water filter that had a crack in it and it only leaked when revved up. Maybe your oil filter has a small leak. Look anywhere there is direct access to the crankcase. Breather, dipstick, oil pressure sending unit, filter, PCV, etc.
  4. Done Swimmin
    Done Swimmin Well-Known Member
    195
    2
    Dec 3, 2007
    Canada
    Local Time:
    4:55 AM
    Run it with the fan off and the hood up and you will see where it is coming from. My bet is the dipstick tube!
    pete
  5. alwaysamopar
    alwaysamopar Well-Known Member
    115
    0
    Jul 25, 2008
    Tucson Az
    Local Time:
    3:55 AM
    I second that!!! Does it have a pcv ? Breathers on valve covers? When i was 16 I had bought some valve covers for my dart that i had saved for a while. Got them on and same thing oil EVERYWHERE!!!!! Too young and ignorant to realize that my new cover had no breathers or pcv hole :(
  6. NorthernSwede
    231
    0
    Sep 12, 2009
    Luleå, Sweden
    Local Time:
    10:55 AM
    pcv beeing? But i does have breathers on the valvecovers, what could be the reason for this excessive pressure then? To my knowledge and my friends all parts are stock but then again we might both be wrong, oilfilter is a new mann filter checked the dipstick and there's no oilpressure meter
  7. slant6/4speed
    slant6/4speed Well-Known Member
    691
    1
    Feb 23, 2010
    New Hampshire
    Local Time:
    4:55 AM
    First are we sure its engine oil and not power steering or maybe ATF?
  8. NorthernSwede
    231
    0
    Sep 12, 2009
    Luleå, Sweden
    Local Time:
    10:55 AM
    Yeah quite, there's no power steering or anything else that could possibly leak by revving under the hood
  9. slant6/4speed
    691
    1
    Feb 23, 2010
    New Hampshire
    Local Time:
    4:55 AM
    I have had a Powerflite tranny "throw up" once. ATF was everywhere under the hood. It had come out the dip stick tube. Did it once and never again. On a 56 Dodge.
  10. slant6/4speed
    691
    1
    Feb 23, 2010
    New Hampshire
    Local Time:
    4:55 AM
    How much of a oil loss shows up on the engine dip stick?
  11. duster340
    duster340 street racer
    2,045
    3
    Mar 13, 2005
    sweden
    Local Time:
    10:55 AM
    i would not bet my life on it,but check around the oilfilter, have had two engines where the oilpumps have had some kind of problem regulating the oilpreasure,ending upp with massive amounts of oil on the bandaged headers,twice resulting in underhoodfires. have also blown an oilfilter,good thing that happend in the garage,i still have the spots on the pillar as prof it got all the way to the roof.. changed oilpump and that fixed it.
  12. plymouth67
    plymouth67 It be a lot cooler if you did...
    1,779
    2427
    Sep 13, 2010
    illinios
    Local Time:
    3:55 AM
    You said the motor has breathers in valve covers, but are they plugged with old dirty oil? It would not be the pcv valve as when you stand on it the vacum to the pcv valve is gone and the valve is shut under hard throttle so it has to be the breathers. They are cheap just put new ones in,and see what it does.
  13. momoparman
    momoparman MOISMYHOME
    3,084
    330
    May 31, 2008
    M I Z Z O U
    Local Time:
    3:55 AM
    "Fan off and hood up" with safety goggles...second the notion.
    You want to find the problem before you start changing things.
    mop
  14. momoparman
    3,084
    330
    May 31, 2008
    M I Z Z O U
    Local Time:
    3:55 AM
    Also if the valve covers don't have baffles at the breather hole location and you have cheap/old breathers and no pcv hooked up you will get a lot of oil loss that can and will migrate all over the engine eventually getting blown around by the fan.
