Docmcg
I’d like to remote mount my oil filter in my ‘65 A100 with the /6. Just think it was ridiculous that Mopar chose to mount a filter upside down! Has anyone done this and is there a recommended kit? Thanks,Steve.
Disagree? Would you like pictures?I’d like to remote mount my oil filter in my ‘65 A100 with the /6. Just think it was ridiculous that Mopar chose to mount a filter upside down! Has anyone done this and is there a recommended kit? Thanks,Steve.
www.forabodiesonly.com
I understand completely. I just have disdain for remote filter kits because sooner or later, ALL OF THEM leak, even if it's just enough to collect dust and dirt. I've tried from Mr Gasket to Canton and most in between so good luck!Nice write-up RRR. The motor in my A100 is in a dog house cover and access to anything is tight. Therefore a remote mounted filter seems to make sense. I had a ‘69 Valiant race car with a 512 stroker. Very crowded engine bay demanded a remote mount filter. Located filter over the battery tray area, made filter changes very quick and easy.
Done it. It'll still seep.That’s what I should have done
That's really cool. Does the return side have a check valve in it? If not, it will still drain at least what's in that return hose back into the pump and through the pickup into the pan. That's why they used the long stand pipe with the check valve in it from the factory. They still didn't work very well, though.Well guys, here it is. Made a plate tha bolts to the back of the block. I’m pretty satisfied it will work.
