WAYNE0
Wasnt sure where to post this. Who here knows about oil furnaces ? Here is my issue- unlike last winter i was able to paint in my one bay garage with the oil furnace running. Not this year. Not sure whats different. Any ways- my garage is 16 x 30 & i do body work & paint work in the same bay. I have an exhaust fan at one end & i have intake filters on the garage door at the other end where the windows were. Just 2 The furnace is in a small room just about double the size of the furnace & thats where the walk in door is. I also have a whole in the wall with a filter a the size of a plastic bucket right beside the furnace for fresh air from outside. When im spraying i also have the walk in door cracked a bit for fresh air for the furnace. Now twice this year as im spraying with the furnace on & when it kits on it will make a big bang & blow the chimney off. It did it twice & both times i had the exhaust fan running. With the walk in door cracked in which is right in front of the furnace & the whole in the wall to the outside i cant believe the furnace isnt getting enough air. Sorry so long. Thanks
