Oil light on at idle when warm.
Slant 6 Engines
  1. John H.
    John H. Member
    18
    1
    Sep 3, 2016
    Cape Girardeau,MO.
    Local Time:
    5:24 PM
    1967 225. Will a heavier oil help with oil light flickering at idle.
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    36,896
    17036
    Jun 12, 2010
    The Wolverine
    Local Time:
    6:24 PM
    What's your idle set at? Sometimes just bumping up the idle a tad will take care of that.
    Of course if it hasn't been rebuilt then the bearing clearances may be an issue.
  3. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    1,499
    2110
    Jan 18, 2019
    Farmington MN
    Local Time:
    5:24 PM
    Slant 6s had issues with leaky oil send units, might want to try that.
  4. philip's66
    philip's66 Well-Known Member
    101
    43
    Feb 11, 2011
    Houston,Texas
    Local Time:
    5:24 PM
    I had a loose connection on my sender it would flicker on & off. Replaced it with a gauge. No more troubles& i know i have good oil pressure
    • Agree Agree x 3
    • missing linc
      missing linc Loose nut behind the wheel FABO Gold Member
      779
      972
      Feb 17, 2019
      Southern Alberta Canada
      Local Time:
      4:24 PM
      If you have a gauge, try checking actual pressure with it, sending units for the light rely on a spring inside which eventually gets contaminated with oil and send false signals. At the minimum, try replacing the sending unit, they're fairy cheap and simple to change. Heavier grade oil will help, but is only a band aid solution, and not good if you drive in cold weather.
      • Agree Agree x 1
      • Mike69cuda
        Mike69cuda 64 is the new 17 FABO Gold Member
        1,053
        756
        Jan 2, 2018
        Overland Park Kansas
        Local Time:
        5:24 PM
        I run 20W50 in my old Trans am that has the same issue during the summer. No effort fix to the problem.
      • missing linc
        779
        972
        Feb 17, 2019
        Local Time:
        4:24 PM
        My 1990 Bronco was doing the same thing, checked with a mechanical gauge, it is a bit low, but a new sending unit installed and no more flickering light at idle, running 10w30 oil.
      • 69a100
        69a100 Well-Known Member
        97
        43
        Jun 29, 2009
        Local Time:
        3:24 PM
        Not if your a couple/few quarts low on oil!
      • emsvitil
        emsvitil Well-Known Member
        492
        468
        Mar 14, 2015
        SoCal
        Local Time:
        3:24 PM
        The pressure relief piston on the oil pump may be stuck open.
      • SGBARRACUDA
        SGBARRACUDA ROY FABO Gold Member
        15,514
        4775
        Dec 7, 2006
        PLANT CITY FL. and PERRY GA.
        Local Time:
        6:24 PM
        The light is designed to come on at Approximately 7 psi. I would venture to guess the oil pressure is low at normal running temperature. A mechanical gauge will clear this mystery right up.
        • Agree Agree x 1
        • Slantsix64
          Slantsix64 Well-Known Member
          2,059
          741
          May 11, 2014
          SGV
          Local Time:
          5:24 PM
          Yes, Heavy oil does increase oil pressure.
        • slantsixdan
          slantsixdan =..=
          6,403
          1504
          Jan 7, 2007
          Vancouver BC
          Local Time:
          3:24 PM
          Don't just throw heavy oil at it—not unless/until you're sure it's due to worn bearings. Other posters here are right: use a mechanical pressure gauge to find out what the oil pressure actually is at hot idle. If you don't want to go to the hassle, replacing the sender's a good bet; they tend to get lazy with age and can cry "wolf". And inspect the sender wire; if it grounds out anywhere along its length, the light'll go on.
          That said, it will also be a good idea to service the oil pressure relief valve to make sure it's doing its job, as described in these two threads: thread 1, thread 2. If that valve sticks partway open, it'll drop your oil pressure.
        • C130 Chief
          C130 Chief Mechanical Genius
          3,011
          155
          Nov 23, 2005
          Boise, ID
          Local Time:
          4:24 PM
          As per Dan. Take the oil pump assembly off the engine and clean it out thoroughly especially the pressure relief valve. Sometimes they crud up and the relief valve sticks. If the engine has had sludge issues, drop the pan and clean the oil pump pickup.
        • barbee6043
          barbee6043 barbee 6043 FABO Gold Member
          11,425
          4095
          Jul 20, 2008
          Shepherd, Texas ( SE Tx)
          Local Time:
          5:24 PM
          I always replace the light for a gauge if the pressure is questionable. Then you actually know whats what.
          • Agree Agree x 2
          • RustyRatRod
            RustyRatRod Weenie idiot loser. FABO Gold Member
            57,464
            27016
            Jun 7, 2010
            Georgia
            Local Time:
            6:24 PM
            Oh hogwash. Stick with the original plan. Idle it up and run thicker oil. And if you think you hear a noise, turn the radio up. Why in the world would you want to diagnose anything and fix it right? That makes no sense at all.
            • Like Like x 1
            • slantsixdan
              slantsixdan =..=
              6,403
              1504
              Jan 7, 2007
              Vancouver BC
              Local Time:
              3:24 PM
              That's not quite as per Dan. There is no need to go to the (considerable) hassle of removing the oil pump from the engine.
            • Mike69cuda
              1,053
              756
              Jan 2, 2018
              Local Time:
              5:24 PM
              Surprised nobody has mentioned the obvious......take the bulb out. Ha!
              • Like Like x 2
