Oil or oil-free air compressor
Shop, Garage and Tools
  1. pauls340
    pauls340 Well-Known Member
    831
    19
    Dec 4, 2008
    17 miles N of Detroit
    Local Time:
    6:04 AM
    Last year I replaced my 23 yr old Craftsman compressor with a vertical Harbor Freight POS Central Pneumatic oil lube unit, 21 gallon. Besides being the loudest compressor i've ever heard, it spits oil everywhere. I've tried every level of oil short of running it with no oil. What am i doing wrong?
  2. Cope
    Cope Fusing with fire
    4,502
    5466
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    5:04 AM
    We have the HF motor on our compressor and it is loud but it dont spit oil?
    In fact inhave a spare motor sittin in the box beacuse it was on sale and in a open box... got if for almost nothing and couldn't pass on it.
    Not sure why yours spits oil?
    Where is it spitting out of?
  3. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    54,521
    40388
    Jan 18, 2006
    Iowa
    Local Time:
    5:04 AM
    Too bad everyone can't buy a QTV580E Quincy.
  4. MoparLeo
    MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
    578
    350
    Feb 10, 2016
    Moreno Valley, Cal. So. Cal.
    Local Time:
    3:04 AM
    Put a bigger muffler on it or make one. In take filter side. Run a long hose to it put the filter container away from the compressor. Like putting your cars muffler at the rear of the car. The farther from the valve, the more effective it is.
    • Like Like x 2
    • zkx14
      zkx14 Duster De-ruster FABO Gold Member
      25,900
      21220
      Dec 23, 2012
      South Central PA
      Local Time:
      6:04 AM
      I have a HF Horizontal oil lubed-VERY loud compared to the probably 30 year old Cambell Hausfeld it replaced. Have had over a year now. Guess I never really though about where the noise is coming from. Might try this...
    • Demonic
      Demonic Well-Known Member
      1,427
      1110
      Mar 21, 2015
      Maryland
      Local Time:
      6:04 AM
      Find an old Champion compressor and put a set of valves in it.
      Oil-less air compressors usually aren't as durable for long term use. The teflon rings get too hot with a high duty cycle.
    • Dicer
      Dicer Diceman FABO Gold Member
      1,156
      1559
      Jan 12, 2016
      Land of Lincoln
      Local Time:
      5:04 AM
      Break in the new Air Compressor as follows: a. Turn the Power Switch off and unplug the unit. Insert a male coupler (sold separately) into the female Quick Coupler and fully open all regulators and valves. b. Plug in the Power Cord. c. Turn the Power Switch ON. d. Let the unit run for 30 minutes. Air will expel freely through the Coupler. (copied from the manual)
      This break-in period is very important, it's printed in the manual, a must do for direct drive compressors.
      • Like Like x 1
      • halifaxhops
        halifaxhops It's going to get stupid around here! FABO Gold Member
        61,856
        30568
        Jan 20, 2014
        Hoppyworld
        Local Time:
        6:04 AM
        I have always had oiled belt driven compressors. Break in is the key like Dicer posted. I had a 21 gallon HF compressor never really had a problem except it is loud, got ten years out of it. No idea why yours is spiting oil. I Just replaced it with a husky, yes quieter but longer to build up. Run from the oiless, never had any luck with them
      • volaredon
        volaredon Well-Known Member
        235
        51
        Feb 28, 2010
        IL
        Local Time:
        5:04 AM
        Champion, Quincy or Jenny/Emglo oil type compressor.... don't waste time on oilless…. if money allows go for an Atlas/Copco or a (are these guys still in business?) Saylor-Beall....
        • Agree Agree x 2
        • Keith Mopar
          Keith Mopar Mopar Nut
          2,987
          1226
          May 15, 2005
          Calgary AB.
          Local Time:
          4:04 AM
          One thing I noticed about my oil less (power fist) is it noisier and takes forever to get started with building air pressure especially if the garage is a bit cool inside, my old one a emglo which I still have in the other garage pumps air quickly cold or warm. One garage is heated and one isn't so that's why I originally switched them. I may have to put them back!
        • Righty Tighty
          Righty Tighty Well-Known Member
          645
          443
          Aug 16, 2019
          Sahuarita, AZ
          Local Time:
          4:04 AM
          Once I bought an oiled compressor, I will never go back to oil-free unless it's a small pancake style and I have no choice. Oil-free compressors don't last as long and are annoyingly loud. The compressor is often times the heart of your shop, so don't skimp and do it right the first time. I have always had US made Campbell-Hausfeld compressors, but I got lucky and scored a great deal on a Quincy QT-7.5. It's hands down the best compressor I've ever owned.
          • Agree Agree x 2
          • toolmanmike
            54,521
            40388
            Jan 18, 2006
            Iowa
            Local Time:
            5:04 AM
            The Quincy QT's are top notch. I sold them for many years.
            • Like Like x 1
            • toolmanmike
              54,521
              40388
              Jan 18, 2006
              Iowa
              Local Time:
              5:04 AM
              Ingersoll Rand makes good compressors as well.
              • Like Like x 1
              • Agree Agree x 1
              • 512Stroker
                512Stroker We are all here because we are not all there.
                1,876
                1321
                May 30, 2016
                Freedom, MO
                Local Time:
                5:04 AM
                Send that Chinese piece of crap back and get a real belt driven shop compressor with an oil sump. Just remember to change the oil and you'll be fine.
              • Car Nut
                Car Nut Mopar Master
                17,950
                76180
                Dec 28, 2018
                Trump Train
                Local Time:
                4:04 AM
                This model number doesn’t show up anymore, is there a replacement model?
              • toolmanmike
                54,521
                40388
                Jan 18, 2006
                Iowa
                Local Time:
                5:04 AM
                QT is the compressor series
                V is verticle
                5 is 5 horsepower
                80 is 80 gallon tank
                E is electric
                • Thanks! Thanks! x 1
                • Car Nut
                  17,950
                  76180
                  Dec 28, 2018
                  Trump Train
                  Local Time:
                  4:04 AM
                  Do they all use the Baldor motor still? Do you think a 60 gallon would be good for a paint gun?
                • toolmanmike
                  54,521
                  40388
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  5:04 AM
                  I think they do. That Qt might be a old number but I bet they have something comparable.
                  • Car Nut
                    17,950
                    76180
                    Dec 28, 2018
                    Trump Train
                    Local Time:
                    4:04 AM
                    I was looking at them for a while and QT is still available.
                  • Demonic
                    1,427
                    1110
                    Mar 21, 2015
                    Maryland
                    Local Time:
                    6:04 AM
                    • toolmanmike
                      54,521
                      40388
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      5:04 AM
                      A 60 is fine for one guy. It will keep up with pretty much anything.
                      • Agree Agree x 1
                      • jas0162
                        jas0162 Well-Known Member
                        554
                        350
                        Apr 23, 2014
                        kansas
                        Local Time:
                        5:04 AM
                        I’ve been running a “puma” v-twin pump that I think is Chinese, not sure. A guy at work gave me the pump and motor. I made it come on when my other compressor starts up, now I can use the blast cabinet all day and it maintains 100lbs. It has worked well for several years.
                        • Blainethemono
                          Blainethemono Well-Known Member
                          114
                          95
                          Mar 14, 2020
                          Seattle
                          Local Time:
                          3:04 AM
                          Im a Campbell Hausfeld kinda Guy myself. About 15 years ago I bought a 220v retail version for $400. While hooking it up, I had issues with the control module. Called CH, and the Support Guy on the other end was awesome. He determined the issue, then said, "let me send you our Commercial Compressor instead". Free shipping to my location, and they took the defective one away. I ended up with a BRAND NEW 80 GA Commercial compressor for the cost of a retail, refurbished POS... It was an $800 Compressor the time!!
                          Been a work horse ever since, and Ive been a CH Fan ever since as well.
                          • Car Nut
                            17,950
                            76180
                            Dec 28, 2018
                            Trump Train
                            Local Time:
                            4:04 AM
                            I have 26 gallon Campbell Hausfeld now going on 18 years, good unit. It can’t keep up with my Dynabrades and I need the room, so sadly it’s got to go .
                            • Like Like x 1
                            • Pawned
                              Pawned N.R.A. Lifetime Member - And damn proud of it
                              1,475
                              178
                              Jun 29, 2013
                              Valle del Sol, AZ
                              Local Time:
                              4:04 AM
                              I think I had the same 21 gallon gallon you had. I finally got sick of it. The noise was terrible, I could not run it except during the day and that was with the garage door closed, the neighbor across the street told me it was too loud and for some reason it did not lube the piston and it froze twice on me. So a buddy had a tank laying around that was fairly big and took up too much room.
                              I took it off his hands, bought the compressor from Harbor Freight. I was using a 5hp gas motor, I had lying. But I got tired of climbing a ladder to check and refill the gas. So I bought a 5hp 220 vac motor, and it is so much quieter than the 21 gallon, its amazing.
                              The other advantage is I could paint my car without waiting for the compressor to refill.
                              The picture is the new build and on the left is the 21 gallon. I think this picture shows the gas engine, before I replaced it
                              If memory serves, I think I spent less than $500. I think it is at least 90 gallons
