There is no need to use a high volume pump unless you are going to be turning the engine in excess of 6000 rpm on a regular basis. I have no personal experience but there is a concern that a high volume oil pump can suck a srock pan dry at higher rpm's
Over filling the oil pan is worse than having it under filled. The crank will wipe the oil up into foam reducing power and causing air to get into the oiling system.
