OIL PAN BAFFLING
A/MP
I'm looking for a stocks sump or 1+ QT that has good baffles. Should fit an early A. Can't find any catalog info.
As mentioned or make one by cutting off the bottom, kicking the sides out some and welding a new flat bottom and triangle corners...and baffle it. Good luck.
yep
I run a Kevco 5qt pan. Fits in the K Member without any alterations. They weld in a crank scraper and baffle. Welds are a little ugly but who sees it.
