Oil Pan Straighten
Big Block A body Tech
  1. roadrunnerh
    roadrunnerh Well-Known Member
    2,956
    202
    Jul 11, 2011
    Pittsburgh, PA
    Local Time:
    7:04 PM
    Well, I screwed up a nice oil pan on my 383 by over tightening. I'm making some progress straightening this out, but using odd combos in effort to hammer the right area. I've read about people "using a 2x4" but I can't imagine how that was effective.
    How about you? What have you specifically used to straighten out an oil pan?
  2. Bodyperson
    Bodyperson A little sketchy
    2,902
    3040
    Nov 26, 2015
    NW MONTANA
    Local Time:
    6:04 PM
    You use the 2x4 to back up the rail as you use two ball peen hammers to reverse the bolt holes back to or a little past flush. Use 2 hammers so the blow to the hole is in the right spot.
    • Agree Agree x 3
    • roadrunnerh
      2,956
      202
      Jul 11, 2011
      Pittsburgh, PA
      Local Time:
      7:04 PM
      I can see doing that for the bolts holes - I think.
      But what about straightening the rails?
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      55,180
      23603
      Jun 7, 2010
      Georgia
      Local Time:
      8:04 PM
      I use the edge of my vise jaws. Just put the pan rail down on it, get a small ball peen hammer and tap the bolt holes back flat.
    • mopar head
      mopar head Well-Known Member
      2,680
      387
      Oct 21, 2008
      Right here, can`t you see me?
      Local Time:
      7:04 PM
      For the rails, use a piece of flatbar the width of it, or a piece of hard wood for backup.
    • famous bob
      famous bob mopar misfit FABO Gold Member
      13,909
      4341
      Aug 14, 2011
      okla
      Local Time:
      7:04 PM
      Another UNBELIEVEABLE !
    • threewood
      threewood Well-Known Member
      376
      202
      Nov 11, 2014
      Yuma
      Local Time:
      6:04 PM
      I've straightened one by laying it down on a flat section of smooth concrete and worked it with a hammer.
    • mopar head
      2,680
      387
      Oct 21, 2008
      Local Time:
      7:04 PM
      What are ya trying to say?
    • pishta
      pishta I know I'm right....
      15,220
      4856
      Oct 13, 2004
      Tustin, CA
      Local Time:
      5:04 PM
      If your tapping a hardened hammer with another hardened hammer, please wear safety googles. The 2x4 allows a little positive give so your overcorrecting the damaged spot. Metal is springy, it takes a little more effort get it past flat to have it hold.
