Oil Pickup For 187 Pan
Big Block A body Tech
  1. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    60,785
    32445
    Jun 7, 2010
    Georgia
    Local Time:
    10:51 PM
    What is the correct oil pickup for the 187 big block pan? Thank you drive through.
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    52,810
    17800
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    9:51 PM
    Pay here, pick up order at next window... :D
    • Like Like x 3
    • Lefty71
      Lefty71 Well-Known Member
      244
      178
      Nov 7, 2013
      Ohio
      Local Time:
      10:51 PM
      • Thanks! Thanks! x 1
      • Jim Lusk
        Jim Lusk Well-Known Member
        4,367
        730
        Mar 8, 2006
        Fresno, CA
        Local Time:
        7:51 PM
      • RustyRatRod
        60,785
        32445
        Jun 7, 2010
        Georgia
        Local Time:
        10:51 PM
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        15,333
        4228
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        9:51 PM
        187 does not have baffles unless somebody installed them. Should have a straight tube, not the squiggly 1. Kim
        • Agree Agree x 3
        • Like Like x 1
        • LS&S
          LS&S Member
          17
          7
          Jun 9, 2019
          Aylett, VA
          Local Time:
          10:51 PM
          I have same pan/same problem.
          What pickup did you use?
        • RustyRatRod
          60,785
          32445
          Jun 7, 2010
          Georgia
          Local Time:
          10:51 PM
        • LS&S
          LS&S Member
          17
          7
          Jun 9, 2019
          Aylett, VA
          Local Time:
          10:51 PM
          That's the one I bought. Pan does not lay flat on pan rails of block. I end up with 1/4-3/8" space between.
          Did you have to make any alterations to 187 pan?
        • RustyRatRod
          60,785
          32445
          Jun 7, 2010
          Georgia
          Local Time:
          10:51 PM
          Haven't used it yet.
        • LS&S
          LS&S Member
          17
          7
          Jun 9, 2019
          Aylett, VA
          Local Time:
          10:51 PM
          Hope you have better luck than I
        • oldkimmer
          15,333
          4228
          Nov 11, 2006
          Local Time:
          9:51 PM
          There is a few comments on summit about it being too long so they cut 1/2 to 3/4 inch off of the threaded end. I know Chrysler listed a low deck and raised deck pick ups as different numbers. Kim
          • Like Like x 1
          • Lefty71
            244
            178
            Nov 7, 2013
            Ohio
            Local Time:
            10:51 PM
            I thought Mancini had the correct pickup tubes to work in this application, but I'll have to go dig thru some papers and pix for a confirmation....
          • 67Dart440GT
            67Dart440GT Seriously Long Member FABO Gold Member
            2,576
            617
            Mar 15, 2010
            53545
            Local Time:
            9:51 PM
            I have one I can send a picture of if you want
          • moparmarks
            moparmarks FABO Gold Member FABO Gold Member
            837
            376
            Oct 5, 2014
            Western Colorado
            Local Time:
            8:51 PM
            Sounds like the one from Summit should be for a 6qt. pan.
          • Lefty71
            244
            178
            Nov 7, 2013
            Ohio
            Local Time:
            10:51 PM
            Looks like the one from Summit is for 6 qt. RB motors.... here's my limited knowledge on the subject. See attached pic, the three pickups on the right are Melling 63-S3 and Mopar P4529565. Those three pickups are identical and interchangeble in every way, as far as I can see; 3/8" tube, six quart RB applications (but not 62-65 B bodies). 5 and 6 quart stock pickups 4[1].jpg
            The 4th pickup from the right side is an RB application, 5 quart pan. The two pickups on the left are identical, one is damaged bad, and the second one is the only of this stack that would work, with a ( 5 quart) 187 pan on a "B" engine big block, as confirmed during a build last year. Unfortunately, I don't have part numbers for the three pickups from the left side. I could make an educated guess, but it would still be a guess. The best info I could find at my fingertips would be to go on the 440 source website, and look at the original part numbers listing for the oil pans by application, because it does include the pickup numbers there. HTH, Lefty71 (wish I had a better answer for you).
            • Like Like x 1
            • Lefty71
              244
              178
              Nov 7, 2013
              Ohio
              Local Time:
              10:51 PM
              Note the much deeper angle at the screen end (closer to 90) on this damaged OEM pickup for the "B" engine with "187" pan, as opposed to the sweeping angle on the pickups for "RB's" with 5 & 6 quart pans shown above it. Stock 5 quart pickup[1].jpg
              • Like Like x 1
              • DC Dart
                DC Dart Member
                10
                0
                Dec 18, 2019
                Oregon
                Local Time:
                7:51 PM
                A while back I drilled and tapped for a 1/2 inch oil pickup. And have the 187 pan. Is there a 1/2 pickup available?
              • Lefty71
                244
                178
                Nov 7, 2013
                Ohio
                Local Time:
                10:51 PM
                You may be able to figure something out, but as far as I know, there was never a Hemi powered car, or other factory 1/2" oil strainer used with a #187 pan, so that's uncharted waters. I could always be wrong of course. Milodon makes a 1/2" connection strainer that may work, but peeps have been bitchen that at this point, it's just a bastardized 3/8" version, so there was no point in reworking your block for no gain. The other thing is, I'm not seeing a #2532264 3/8" strainer anywhere, anymore either.... just Hilltop, and I think his information, or his picture is bogus.
              • LS&S
                LS&S Member
                17
                7
                Jun 9, 2019
                Aylett, VA
                Local Time:
                10:51 PM
                My Solution
                Purchased Pittsburgh 91395, NPT tap and die kit at Harbor Freight
                Used 3/8x18 NPT tap and CRC 92581 cutting lube to tap the threads in the block. Took about 3 full turns overall, before I got the Melling 63-S3 low enough that 187 pan would seat on pan rails with gasket.
                Lefty71 is right. Pickup with shape in picture would have been much easier.
              • RustyRatRod
                60,785
                32445
                Jun 7, 2010
                Georgia
                Local Time:
                10:51 PM
                Gosh yall, this is really much ado about nothing. The red wrench will come right out and make easy work of however it needs to be bent and do a nice job.
              • LS&S
                LS&S Member
                17
                7
                Jun 9, 2019
                Aylett, VA
                Local Time:
                10:51 PM
                What is the red wrench?
              • RustyRatRod
                60,785
                32445
                Jun 7, 2010
                Georgia
                Local Time:
                10:51 PM
                This here......
                • Like Like x 1
                • LS&S
                  LS&S Member
                  17
                  7
                  Jun 9, 2019
                  Aylett, VA
                  Local Time:
                  10:51 PM
                  Got it. Thanks
