bill detamore
Hey guys.
I am new here. I have a quick one for you. I have a 71 Scamp with a 318. I recently had a manifold, carb and ignition installed. Since then, I have my oil light on the dash on at idle. My thinking is that the idle is just a bit low. When it is not in gear, the light has a flicker and if I give it just a bit of pedal, the light goes out. When I put it in gear, the light is on but again as soon as I give it a bit of gas, it goes out.
The motor runs really smooth and strong. Starts up as soon as you turn the key, no smoke etc. The light never goes on at any other rpm. Right now I do not know what the idle is set at, rpm.
Thoughts?
Thanks a bunch.
Bill D
Thoughts?
Thanks a bunch.
Bill D
