Oil PSI light, H20 temp light?
Big Block A body Tech
  1. Cope
    Cope Fusing with fire
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    Im thinking about adding a oil psi light and just looking at kits and such it look like i can just about buy any pressure sending unit and T it off my gauge.
    my guestion is would the single wire on the sending unit be ground? and hot to the light?
    Thanks.
  2. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    24,952
    4261
    Aug 28, 2009
    Ontario
    Local Time:
    1:36 AM
    Are you trying to add an " idiot light" or trying to light up a gauge?
  3. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    I have an autometer gauge but I want an idiot light also just incase..
    what PSI would be considered low?
    also i want a temp light, H20 temp idiot light should the light come on, 220? I run around 190 in traffc.
    Thanks.
  4. 4spdragtop
    24,952
    4261
    Aug 28, 2009
    Ontario
    Local Time:
    1:36 AM
    I believe the sender is self grounding. So only one wire. Im not sure if they can both function from the same sender??
    I have an autometer as well but its mech style.
    I would think min 25 psi and yer good. Dads never gets below 40
  5. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    yes the sender is grounded but the sender is not a hot wire? correct?
    so hot wire to light, ground to sender?
    my.plan is to run dual sending units, one for the light and one for the gauge.
  6. 4spdragtop
    24,952
    4261
    Aug 28, 2009
    Ontario
    Local Time:
    1:36 AM
    Run coolant water at 50/50 and 220 should be ok.
    I have autometer water temp and oil psi aftermarket mounted on lower edge of dash. we left factory gauges in dash as we like stock look. The gauges worked but they are still almost 50 years old.
  7. 4spdragtop
    24,952
    4261
    Aug 28, 2009
    Ontario
    Local Time:
    1:36 AM
    For me the coolant sensor has only one wire to it. I cant remember how many wires go to gauges.
    Chk autometer website out for the wiring?
  8. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    47,999
    13377
    Jun 7, 2010
    Georgia
    Local Time:
    2:36 AM
    Run hot to the light on one side and the switch to the other side from ground, yes. The PSI ranges from 3-7 to cut the light on.
  9. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    ok so who makes a sending unit that trips/opens at 3/7 PSI?
    and 220 degrees is ok for H20 temp?
    shit what is to hot, i get worried around 210....
  10. RustyRatRod
    47,999
    13377
    Jun 7, 2010
    Georgia
    Local Time:
    2:36 AM
  11. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    Ok, ok..
    Thats what i thought. any generic sending unit and a raidio shack 12v light should work.
    what about H20 temp sendimg unit?
  12. 4spdragtop
    24,952
    4261
    Aug 28, 2009
    Ontario
    Local Time:
    1:36 AM
    Straight water boils at 212* Chk coolant jug to see what 50/50 boils at.Different coolants may vary
  13. Cope
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    1:36 AM
    i run a small amount of antifreeze and water weter. so 210 is to hot?
  14. Jlcaptain24
    Jlcaptain24 Well-Known Member
    473
    126
    Apr 21, 2012
    Fort Worth
    Local Time:
    1:36 AM
    I did the same thing for my dart....guage plus lights.
    Here's the sender I used:Oil Pressure Switch - W/ Light-440 Source
    I used little LED flush mount bolt lights from here: Flush Mount LED Bolt | Oznium They're bright at shit, so wired in a 3Kohm resister inline with them which reduced them perfectly. Flush, clean little lights. Above poster is correct....the sender is self grounding.
  15. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    47,966
    16090
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    2:36 AM
    You can get a temp switch at just about any range you want.
  16. RustyRatRod
    47,999
    13377
    Jun 7, 2010
    Georgia
    Local Time:
    2:36 AM
    No 210 is not too hot. Not even for plain water. Rememper the system is under pressure.
  17. TrailBeast
    TrailBeast Slightly Twisted Member
    19,224
    5567
    Mar 11, 2011
    Arizona
    Local Time:
    12:36 AM
    You can also get adjustable switches and set it for whatever pressures you want it to come on at.
    And yes, keyed power to the light and the sender grounds it when the pressure is too low.
    Basically what happens is the light would come on when you turn the key on and then go off when your oil pressure came up.
    Just an FYI, you can do exactly the same thing with buzzers for an audio warning.
    One of my cars had all three (gauge, idiot light and a buzzer) for oil pressure, temp, and charging system.
    I had a switch that you could turn the buzzers off or on with if you didn't want audio and just gauges with idiot lights.
    Not to long ago on here we discussed how to make the gauges and speedometer backlighting all turn red instead of an idiot light.
    That was pretty cool also.
  18. 67Dart273
    67Dart273 Well-Known Member
    38,642
    6247
    Oct 14, 2010
    Idaho
    Local Time:
    11:36 PM
    Also, if you are crafty, you can use something like your brake light for the temp warning. "You just have to remember". The brake light is already all hooked up. Just tie into the brake switch wire and run it over to the temp or sender.
    However, remember you must actually get the correct sender. They MUST be for a lamp and not a gauge.
    GM or Ford, can't remember, did this "awhile back," remember? They had an "engine warning lamp" It was branched off to BOTH the temp an oil, one light did two jobs.
  19. TrailBeast
    19,224
    5567
    Mar 11, 2011
    Arizona
    Local Time:
    12:36 AM
    Yep, lights use and on/off type sender switch and gauges use a variable voltage rheostat type sender.
    Heck you could even make something that yelled "AAAAAHHHHH, NO OIL PRESSURE!" :D
    It' all just control switches and something that reacts when switched.
  20. halifaxhops
    47,966
    16090
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    2:36 AM
  21. hangn0ut
    hangn0ut Well-Known Member
    741
    116
    Dec 3, 2012
    rialto.ca.
    Local Time:
    11:36 PM
    Pressure switch? Hobbs. Temp should be at the lowest abnormal temp for that engine. If it never hits 200° set it for 200 not 210 or 220. If the light comes on ocasionally during normal use,thats okay cause it tells you to keep watch on it. Thats my opinion.
  22. AJ/FormS
    AJ/FormS The end is near FABO Gold Member
    15,005
    4149
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    1:36 AM
    And the big caveat; gauges and lights only work if you are looking at them. If your eyes are on them, who is driving? I like to drive, so no gauges here....... Well, I have; a speed-O, and a tach.
    Once in a while I look at the tach.....
    But the Speed-O is my friend. It saves me buckets of money.
