Oil pump gasket?
Discussion in 'Small Block Mopar Engine' started by Valkman, Jun 14, 2018.
  1. Valkman
    Valkman Well-Known Member
    765
    224
    Sep 13, 2012
    NC
    Local Time:
    12:17 PM
    My engine gasket set doesn't have an oil pump gasket. My new oil pump came with one but I've lost it. My question is do you need it?
  2. 69_340_GTS
    69_340_GTS Well-Known Member
    3,067
    1021
    Jul 11, 2014
    Torrington, CT
    View My Photos
    Local Time:
    12:17 PM
    Good idea to have it. You can get some thin gasket paper and make one very easily.
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • brian6pac
      brian6pac Well-Known Member
      3,016
      1509
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      12:17 PM
      Nooooo don't use one, Just make sure both surfaces are flat and bolt it together.
      I have seen those gaskets blow out and you will loose oil pressure.
      • Agree Agree x 1
      • 69_340_GTS
        3,067
        1021
        Jul 11, 2014
        Torrington, CT
        View My Photos
        Local Time:
        12:17 PM
        Don't you just love this board?
        • Agree Agree x 2
        • Like Like x 1
        • yellow rose
          yellow rose Doctor of Thinkology.
          15,415
          12016
          Jun 19, 2015
          Living on the razors edge
          Local Time:
          9:17 AM
          I use them. Personally I've never blown one out.
          • Agree Agree x 3
          • QuickDart360
            QuickDart360 Well-Known Member
            713
            177
            Apr 5, 2014
            San Antonio
            Local Time:
            11:17 AM
            Never used any. Never a problem!
            • Agree Agree x 2
            • grimreaper
              grimreaper Cross Member
              3,673
              461
              Jul 8, 2005
              Gillette, WY
              View My Photos
              Local Time:
              10:17 AM
              I've done both. With and without gasket, never had a problem. But, you can make one pretty easily......
              • Like Like x 1
              • 72Dart6pack
                72Dart6pack Harder Better Faster Stronger.
                2,698
                1732
                Feb 1, 2016
                Roseville Michigan
                Local Time:
                12:17 PM
                My last one I made out of thin sheet copper from the hobby store.
                • Like Like x 2
                • pntastar69
                  pntastar69 Well-Known Member
                  1,389
                  66
                  Dec 28, 2006
                  Gilbertsville, PA
                  View My Photos
                  Local Time:
                  2:17 PM
                • sireland67
                  sireland67 Well-Known Member
                  7,492
                  1436
                  Oct 27, 2010
                  WV
                  Local Time:
                  12:17 PM
                  I buy mine from this guy, his prices are reasonable, and his shipping is cheap.
                  Normally I pick up a 1/2 dozen or so at a time.
                • nm9stheham
                  nm9stheham Well-Known Member
                  9,743
                  2164
                  Dec 20, 2013
                  Waynesboro, VA
                  Local Time:
                  12:17 PM
                  I always put a thin coat of #2 Form-a-Gasket on a gasket like that. Never blown anything like that out. I would prefer to have one.
                • pishta
                  pishta I know I'm right....
                  13,542
                  3303
                  Oct 13, 2004
                  Tustin, CA
                  View My Photos
                  Local Time:
                  9:17 AM
                  flat on flat equals a good enough seal. Look at the Exhaust manifolds of a RB in a motorhome....none! The one supplied with my new pump looked like the receipt.
                • RustyRatRod
                  RustyRatRod Just another dumbass. FABO Gold Member
                  47,475
                  12500
                  Jun 7, 2010
                  Georgia
                  View My Photos
                  Local Time:
                  12:17 PM
                  I've torn down factory assembled engines with and without them. I don't think it makes a difference.
                  • Agree Agree x 3
                  • famous bob
                    famous bob mopar misfit
                    11,030
                    2675
                    Aug 14, 2011
                    okla
                    Local Time:
                    11:17 AM
                    Same here , stock 426 hemi`s came w/ them, that`s good enough for me !!
                    Altho they were very thin! I run a thin one on my 505.
                  • brian6pac
                    3,016
                    1509
                    Nov 15, 2016
                    N.E.Ohio
                    Local Time:
                    12:17 PM
                    I always run them on a BB but never on a SB
                    • Agree Agree x 1
                    • QuickDart360
                      713
                      177
                      Apr 5, 2014
                      San Antonio
                      Local Time:
                      11:17 AM
                      My dad did 16 years at a dodge dealer back in the early 60's thru the late 70's. When he rebuilt a motor 318 or 360 he never used a gasket. He says never a come back!!! So after he opened his auto shop he continued to disregard gasket still never an issue!!
                      • Agree Agree x 1
                      • yellow rose
                        15,415
                        12016
                        Jun 19, 2015
                        Local Time:
                        9:17 AM
                        We'll have him save me a stack and I'll buy them from him.
                      • QuickDart360
                        713
                        177
                        Apr 5, 2014
                        San Antonio
                        Local Time:
                        11:17 AM
                        Sorry went away to the dumpster a good while back!!!!:rolleyes:
                      • skrews
                        skrews Well-Known Member
                        1,176
                        493
                        Jul 20, 2012
                        Washington state
                        Local Time:
                        9:17 AM
                        Don't use them anymore, never a problem here. Never torn down a factory motor (and I've torn down alot) that had one in it, even though I've heard people say they have.
                        • Agree Agree x 2
                        • Like Like x 1
                        • Valkman
                          765
                          224
                          Sep 13, 2012
                          NC
                          Local Time:
                          12:17 PM
                          Thanks all that's pretty much what I figured
                        • famous bob
                          11,030
                          2675
                          Aug 14, 2011
                          okla
                          Local Time:
                          11:17 AM
                          Isn`t a small block pump on the inside or the engine ? Never messed w/ a small block mopar , only sbc.
                        • 1994redram
                          1994redram FABO Gold Member FABO Gold Member
                          964
                          456
                          May 9, 2012
                          Oklahoma
                          Local Time:
                          11:17 AM
                          They are inside the pan where oil pumps belong. Those big block mopars are some strange beasts with their exposed pumps and such. :D
                          There wasn't a gasket in my 360 magnum and I didn't use one when I rebuilt it.
                          • Agree Agree x 1
                          • mullinax95
                            mullinax95 Well-Known Member
                            12,885
                            325
                            Oct 25, 2006
                            Anderson, SC
                            View My Photos
                            Local Time:
                            12:17 PM
                            My IMM Engines built 408 didn't have one.
                          • famous bob
                            11,030
                            2675
                            Aug 14, 2011
                            okla
                            Local Time:
                            11:17 AM
                            personally, I like it being out where a guy can change it, or rebuild, or go bigger w/o pulling the pan. Oil filter up front , easy to get to.---to each his own-
                            • Agree Agree x 2
                            • BigBlockMopar
                              BigBlockMopar BigBlockMember
                              1,537
                              483
                              May 1, 2011
                              Netherlands
                              Local Time:
                              6:17 PM
                              BigBlocks have a lot of advantages compared to the small blocks;
                              The accessible oilpump, distributor in front, no stupid water in intake manifold, simple waterpump design, to name some.
