Oil Pump Leaks…
Slant 6 Engines
  1. SpriceyStuff
    SpriceyStuff Well-Known Member
    162
    32
    Mar 12, 2022
    Richland, WA
    Local Time:
    11:21 PM
    Well guys, I finally have a running project, but it had an oil leak at the pump gasket. Yesterday I tried to make a new gasket for it. I cut a hole for the shaft and a slit to fit around it since I couldn’t get the pump all the way out. I rubbed some oil on the rim of the pump and pressed the gasket material onto it to get an outline of the shape and I then cut the shape out with an X-Acto knife. Then I ran a bead of gasket maker around the whole thing and pressed it onto the pump, bolted it all up. Now, it leaks WAY WORSE. And I can’t figure out why? Please help me guys I have a pool of oil under the car now. I want to start driving it but it’s just fighting me every step of the way. Could it be because I went with the medium thickness gasket material instead of the thin one? The guy at the store seemed to have his doubts when he saw I got the medium one.
  2. MOPAROFFICIAL
    MOPAROFFICIAL FABO Gold Member FABO Gold Member
    11,674
    11245
    Jun 1, 2016
    Oceanside ca.
    Local Time:
    11:21 PM
    You have to pull it and change the gasket.
    Lift up the motor off the mounts some if need be.
  3. SpriceyStuff
    162
    32
    Mar 12, 2022
    Richland, WA
    Local Time:
    11:21 PM
    I tried to Jack the motor up out of the mounts but it seemed to make things worse (left me with less room)
  4. SpriceyStuff
    162
    32
    Mar 12, 2022
    Richland, WA
    Local Time:
    11:21 PM
  5. 66Valiant528
    66Valiant528 Well-Known Member
    545
    316
    Aug 20, 2019
    Medway Ma
    Local Time:
    2:21 AM
    So BB?
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      88,183
      71296
      Jun 7, 2010
      Georgia
      Local Time:
      2:21 AM
      Then you're doin somethin wrong. My 64 Valiant has about a 3" narrower engine bay than yours and I can get my pump off by jacking the engine up off the k frame. It's tight, but it'll come out. You have even more room than I do.
    • RustyRatRod
      88,183
      71296
      Jun 7, 2010
      Georgia
      Local Time:
      2:21 AM
      This is posted in the slant 6 section.
      • Thanks! Thanks! x 1
      • SpriceyStuff
        162
        32
        Mar 12, 2022
        Richland, WA
        Local Time:
        11:21 PM
        Well, the Jack I have rn is small and doesn’t go up very high. My good one was last used by my brother and vanished one day without a trace. Along with my Jack stands… but anyway, the car comes up with the engine a little before the engine finally comes off, and that’s about where my tiny Jack reaches its limit
      • 66Valiant528
        545
        316
        Aug 20, 2019
        Medway Ma
        Local Time:
        2:21 AM
        Ah thanks
      • RustyRatRod
        88,183
        71296
        Jun 7, 2010
        Georgia
        Local Time:
        2:21 AM
        That's bad news. Also, if you have a manual transmission, you really need to disconnect the Z bar from the bellhousing, or you'll risk bending it or the clutch linkage, possibly the same with automatic linkage, so beware. Both mounts really need to be unbolted from the k frame, because the engine needs to be raised a good bit. On mine, it's such a tight fit, I had to pry the engine over to the driver's side with a prybar to get the extra room needed to get the pump out. It's tight, I'll be the first to admit, but your car should have a good bit more room than mine.
        • Like Like x 1
        • RustyRatRod
          88,183
          71296
          Jun 7, 2010
          Georgia
          Local Time:
          2:21 AM
          Sho nuff!
        • SpriceyStuff
          162
          32
          Mar 12, 2022
          Richland, WA
          Local Time:
          11:21 PM
          That
          I need a pry bar too. But mines at my brothers house. Looks like I’ll need to make a trip over there tomorrow and pick up more of my stuff. So many mopar/classic car people in my family sometimes it gets hard to keep track of whose crap is at whose house lol
        • volaredon
          volaredon Well-Known Member
          1,671
          583
          Feb 28, 2010
          IL
          Local Time:
          1:21 AM
          The right gasket from fel pro is only like $4 or so
          For that price get a couple of them.and you NEVER want to cut a gasket.
          I mean cutting one out of gasket paper can be ok, but it has to go on in 1 piece, never split.
        • SpriceyStuff
          162
          32
          Mar 12, 2022
          Richland, WA
          Local Time:
          11:21 PM
          I can never find one. No one in town has the fel-pro gaskets for them anymore. Online they range from $8-$12 on average plus shipping. It’s cheaper to make my own at that point. Thinking I should start producing them lol
        • RustyRatRod
          88,183
          71296
          Jun 7, 2010
          Georgia
          Local Time:
          2:21 AM
          You'll not find them in stock locally anywhere. I always have to order mine and I get three or four when I do.
          $2.99 from oh really.
          https://www.oreillyauto.com/detail/.../a/14645/automotive-car-1974-dodge-dart?pos=0
        • SpriceyStuff
          162
          32
          Mar 12, 2022
          Richland, WA
          Local Time:
          11:21 PM
          That’s strange and odd. Both Autozone and O’Reilly told me they couldn’t even special order it for me cause it wasn’t an option anymore when I called them. I’ll have to order a couple
        • SpriceyStuff
          162
          32
          Mar 12, 2022
          Richland, WA
          Local Time:
          11:21 PM
        • RustyRatRod
          88,183
          71296
          Jun 7, 2010
          Georgia
          Local Time:
          2:21 AM
          Now that you mention it, they don't show in stock anywhere. I just got some not too terribly long ago. I'll talk to my guy at oreilly tomorrow and see what's up. Looks like they might be unavailable.
        • RustyRatRod
          88,183
          71296
          Jun 7, 2010
          Georgia
          Local Time:
          2:21 AM
          Rock Auto is not even showing them. That's a bad sign.
          • RustyRatRod
            88,183
            71296
            Jun 7, 2010
            Georgia
            Local Time:
            2:21 AM
            I just went and looked in my gasket stash. I have two and I'm sure glad. lol There are some on ebay, but at stupid prices.
          • SpriceyStuff
            162
            32
            Mar 12, 2022
            Richland, WA
            Local Time:
            11:21 PM
            That’s what I’m saying. I’m gonna start producing them I think. Maybe partner with my friend who has a cricut machine
          • SpriceyStuff
            162
            32
            Mar 12, 2022
            Richland, WA
            Local Time:
            11:21 PM
            Well guys, what do you think
          • George Jets
            George Jets 1967 Dart 2 Door FABO Gold Member
            7,559
            10640
            Jan 18, 2019
            Farmington MN
            Local Time:
            1:21 AM
            Put thin coat of Aviation Sealer on both sides of that gasket. Take Brake Parts Cleaner to remove oil film off the block and oil pump so the sealer will seal.
            Check your oil pressure sending unit, they can leak like a sieve.
          • SpriceyStuff
            162
            32
            Mar 12, 2022
            Richland, WA
            Local Time:
            11:21 PM
            Yeah mine is definitely leaking. What do I do about that?
          • volaredon
            1,671
            583
            Feb 28, 2010
            IL
            Local Time:
            1:21 AM
            Replace it!!!!! That's what.
            I definitely don't have anywhere near that many left but I got a pack of 10 of those gaskets for $20 shipped, from ebay a while back.
