The only thing they mention about the head is the increased valve size, and they don't actually give any specs. (Ford I: 1.73", E: 1.5")
There would have to be porting of some sort to use these valves. Article is a little 'light' on information in critical areas. Either the author didn't know to ask, or the shop is being secretive. Still, 300 horses is nothing to sneeze at.
The rods alone are $1100 a piece. I guess it makes the 440 guys point...
$6600 in rods???????????? Ummmm I don't think so.........................The a $10,000 engine build. The rods alone are $1100 a piece. I guess it makes the 440 guys point...
Hmmmm, You have a link, 'cause Summit's site won't take that Scat part#, but the 6657's are only around $560 for a set of 8.......we're only buying 6.............That's what the Summit catalog says...
https://www.summitracing.com/search/make/ford?ar=1&N=4294925198
Take your pick, there are 19 listed. But if they really did use a 6.658 rod, then that is a custom job...
Not true, they stated Chrysler made the Slanty in "mostly" the 170 & 225, I guess figuring the three year relatively unpopular run for the 198 wasn't worth thefunny how they missed the 198 slant and claim only the 170 & 225 were made.
