MopaR&D
Nerd Member
OK, that was the setup I was thinking of... could not connect you to it! The big point to the OP is the LA318 heads on the Magnum block need an oiling path added. Since this is a standard truck use, and a stock cam, the ports ought be adequate. But the open chambers are not going to be as good for compression... a step backwards unless you mill them down some IMHO.
I did change my username in the past year or 2 lol it used to be "MOPEkidD-3"
