Opinion on oil
Discussion in 'New Hemi Engine Swaps' started by Edsrt, Nov 20, 2018.
  1. Edsrt
    Edsrt Active Member
    44
    12
    Mar 6, 2018
    Washington nj
    Local Time:
    7:13 PM
    Looking for opinions on oil viscosity on Gen 3 Hemis and maybe people's experience. I am currently putting a 2012 Ram 5.7 together and stock it required 5w20 and since I will not be running mds and may not be vvt I was wondering if I could use a 10 w 30 or 5w30 full synthetic. I always used Mobile 1 or Valvolin Vr1 . Also I was wanting to know if a Zink additive would be useful in a roller cam engine.
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    555
    351
    Jun 27, 2016
    Mich
    Local Time:
    7:13 PM
    5W20 or 5W30 would be fine. No zinc required for roller lifters. You could run zinc on break in, after that run synthetic. 65'
  3. Fast340cuda
    Fast340cuda Well-Known Member
    99
    63
    Jul 25, 2013
    San Jose, ca
    Local Time:
    4:13 PM
    I like Mobil 1 and use it in 2 of my 3 late model hemis. My 2005 5.7 gets 5w-20 and the 2006 6.1 gets 0w-40. They both have over 100k miles on them and run like new.
  4. Map63Vette
    Map63Vette Well-Known Member
    1,514
    25
    Apr 19, 2010
    Lawrence, KS
    View My Photos
    Local Time:
    6:13 PM
    Even without MDS or VVT I would probably err on the side of caution and try to use as close to the stock weight as you can. The whole engine was likely designed with certain tolerances and whatnot around that oil, so it would make sense to stay close. Granted I think most owners manuals will suggest different weights for different climates, so I'm guessing there's a bit of swing in there.
  5. LJ67barracuda340
    LJ67barracuda340 Well-Known Member
    374
    173
    Mar 5, 2012
    Ontario
    Local Time:
    7:13 PM
    just got this in the mail today,,if the upload works it might answer your ?
  6. Peter Bates
    Peter Bates 1973 Cuda owner for 36yrs
    137
    105
    Aug 25, 2018
    Sylvania ohio
    Local Time:
    7:13 PM
    My 392 calls for 0-40 weight. Mopar backed manual
  7. RustyRatRod
    RustyRatRod Just another dumbass. FABO Gold Member
    47,016
    11733
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    7:13 PM
    This is not true. Roller cam engines do require zinc, just "not as much" as a flat tappet engine.
  8. Fast340cuda
    99
    63
    Jul 25, 2013
    San Jose, ca
    Local Time:
    4:13 PM
    Mobil 1 0w-40 had a decent zddp content a few years back and was listed as the factory fill on both my 6.1 and 392 SRT’s. Not sure if they have dialed it back in the last few years.
  9. RealWing
    RealWing Well-Known Member
    653
    132
    Jun 14, 2010
    Ontario
    Local Time:
    7:13 PM
  10. Edsrt
    Edsrt Active Member
    44
    12
    Mar 6, 2018
    Washington nj
    Local Time:
    7:13 PM
    Good article, makes sense about the quality of oil and volatility of thinner oils especially with today's low tension rings witch seem to coke up. I was thinking that going from a 5-20 to 5-30 Would not that much of a change. The thought of 0-16 or 0-8 is pretty scary.
  11. Dennis H
    Dennis H Well-Known Member
    63
    91
    May 29, 2013
    San Jose
    Local Time:
    6:13 PM
    0-30 Amsoil Signature Synthetic in both my 5.7 Hemis. One vvt, one not. Nice additive package to massage seals. 0 gives good start up protection, and 20 is too thin for any climate.
    Both purr. Extended drain too after first change. 06 Daytona and 09 Challenger 6 speed.
  12. gummibear
    gummibear Member
    7
    1
    Mar 17, 2016
    fort collins
    Local Time:
    5:13 PM
    If your putting a stock motor back to stock, all you need the the manufacturer recommended oil. You won't get better protection running thicker oil, you'll just give up power.
    Adding Zinc additives isn't necessary either as those are for older designs using modern oils.
    Manufacturing tolerances are so much better than it used to be which allows for thinner oils in general.
