1. glennstar67
    glennstar67 FABO Gold Member FABO Gold Member
    17
    0
    Sep 18, 2010
    Loveland CO.
    Local Time:
    2:18 PM
    I have a 74 Duster. It has electronic ignition. It started running rough, almost like it was running on 7 cyl or something. Eventually it wouldn't even start anymore. Would just backfire through the carb and then finally it just quit. No power at all. No headlights, domelight, nothing when you turn the key. I figured it was the ign module box.. When I took the old one off there was a hole in it. I'm figuring problem solved. I install a new one. All power comes back. I turn the key, I get one click and all power is gone again. Could it be the starter is bad and drawing too many amps? I've replaced the starter relay as well. I would appreciate any advice. Thank you all in advance.
  2. cosgig
    cosgig MoBro Inc. FABO Gold Member
    10,785
    3181
    Jul 20, 2008
    Pinckney, Michigan
    Local Time:
    3:18 PM
    Connections connections connections! Clean all those connections, especially the grounds!
    • Agree Agree x 6
    • Like Like x 1
    • 67Dart273
      67Dart273 Well-Known Member
      38,641
      6247
      Oct 14, 2010
      Idaho
      Local Time:
      1:18 PM
      Don't guess learn how to troubleshoot. You can download a 73 shop manual for free from MyMopar. That manual and several others over there came from the efforts of guys right here
      Also "somewhere" is a poor quality wiring section for 74.
      Free service manuals
      You need "at the least" a multimeter which you can buy at any auto parts store, hardware store, Lowe's or HD or even Horrid Freight
      Start by examining the condition of the ignition system. Pull the cap and rotor and examine for dirt, moisture, foreign materials, "tracking" around the inside of the contacts, and damage and "punch through" of the rotor. Examing the reluctor and pickup for damage, heavy rust and debri
      Next get/ rig yourself a spark tester. I use a Lisle as it is adustable, less than 10 bucks
      lisle 50850 spark tester - Google Search
      WHEN TESTING THE SPARK it is IMPORTANT to do THREE things minimum
      1....Do not test by jumpering the starter relay to crank the engine. This changes the power path to the ignition system and leads you astray
      2...Do not use the existing coil wire, as it might be a resistance wire and could be defective. Put your spark tester connected to the coil tower to the engine block
      3.....Take your multimeter and connect to the coil + and watch it when you crank the engine USING THE key. You should show AT LEAST 10.5 V or more as it is cranking or more
      The system should produce nice blue snappy sparks at least 3/8" and more typically 1/2" long
      It is much more likely that the coil is going "somewhat bad" than the ignition module.
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      Have checked all of them. Made sure fusible link was ok as well
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      Actually used a multimeter on it. Everything was good, replaced cap, rotor, and coil as well
    • 67Dart273
      38,641
      6247
      Oct 14, 2010
      Idaho
      Local Time:
      1:18 PM
      I found the 74 wiring scan in my computer. I don't remember where or if it ever got put on line. Send me a pm and if you can receive a somewhat less than 10mb file I will send it I scanned this, it is poor but I think readable
    • 67Dart273
      38,641
      6247
      Oct 14, 2010
      Idaho
      Local Time:
      1:18 PM
      So is the spark good an "hot?"
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      Everything I put the mutimeter on read 1.0
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      But there is no spark. No power at all
    • 67Dart273
      38,641
      6247
      Oct 14, 2010
      Idaho
      Local Time:
      1:18 PM
      "Everything" is not a word that computes. You have to be specific. I cannot tell what you are doing
      1...Make sure the meter works. Check the battery voltage.
      2...Is there anything supplied by the ignition switch that does not appear to work? That would be a clue
      3....Do you have a 2 or 4 wire ballast resistor? If you have a 4 wire, there should be one end with both terminals jumpered together. That comes from the ignition switch in "run". Hook your meter to that, put the key in the "run" position and see what you have
      4....Double check the above by checking the blue wire feeding the alternator field. With the key in "run" it should be very close to "same as battery."
      5...It is IMPORTANT to understand that the circuit CHANGES between "run" and "start" positions of the key. The test in (4) only works in 'run'. The 'run' voltage GOES DEAD when you twist the key to "start"
      Hook the meter to coil positive, and twist the key to "start." You should have at least 10--10.5V or more
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      Very good suggestions. I will try all of these tomorrow. Thank you very much for all of your help this evening. I really appreciate it
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      2,925
      1925
      Jun 1, 2016
      breakwater
      Local Time:
      1:18 PM
      Disconnect the ballast and see if you have power
    • glennstar67
      17
      0
      Sep 18, 2010
      Loveland CO.
      Local Time:
      2:18 PM
      Thank you for responding. There is nothing. Completely dead
    • MOPAROFFICIAL
      2,925
      1925
      Jun 1, 2016
      breakwater
      Local Time:
      1:18 PM
      Okay, well if the box is good,coil is good, ballast is good and the magnetic pickup works and its sparking plugs and cranking till battery goes dead...you may have lost a timing chain gear.
    • dirty white boy
      dirty white boy 47 yr old Juvenal delinquent
      1,013
      451
      Dec 15, 2012
      stoneville n.c.
      Local Time:
      3:18 PM
      id check starter relay be sure its grounding good! had the same issue on my D150 other day!! if no power on the start and run wires with key switch on id bet its the electric switch in the steering column the key switch works!!
    • Kent mosby
      Kent mosby FABO Gold Member FABO Gold Member
      179
      99
      Aug 24, 2018
      Idaho
      Local Time:
      1:18 PM
      Are you saying that the distributor is not rotating at all? I am just following this thread to learn.
    • Bad Sport
      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
      34,612
      13576
      Jun 12, 2010
      The Wolverine
      Local Time:
      4:18 PM
      OP, this ^^^^^ is where I would start. Check and clean all power and ground connections.
    • inertia
      inertia Well-Known Member
      3,088
      424
      Feb 4, 2011
      Victoria B.C. Canada
      Local Time:
      1:18 PM
      Charge the battery, or replace with one known good.
      Clean the battery terminals and cable connections, particular " + " one.
      • Agree Agree x 1
      • MOPAROFFICIAL
        2,925
        1925
        Jun 1, 2016
        breakwater
        Local Time:
        1:18 PM
        Oh no... it can still rotate and Spark, see it can even rotate somewhat less than engine speed at cranking because in such a scenario the chain driven by the crank just slipped and re settled on the cam gear setting the cam timing out enough not to run.
        A lot of times they only finally slip in 2 ways "most of the time"... and that's under hard acceleration and more under deceleration, inertia takes over at a point when the chain and gear is just too loose and worn.
        Hope that sheds some light.
      • Kent mosby
        179
        99
        Aug 24, 2018
        Idaho
        Local Time:
        1:18 PM
        But he says there is no spark at all. (Post #9) I understand if a gear slipped he would spark but not at the right time. Without a spark at all, either there is no signal to send a spark or there is a broken component to generate the spark, be it coil, wire or Dist. If the shaft of the dizzy is broken or the drive for it (timing gear) then no signal to generate a spark would be sent, thus no spark. To test that the dizzy is turning at all take the cap off and crank it and watch it spin. Unlikely, but an easy check.
      • AJ/FormS
        AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s FABO Gold Member
        15,004
        4148
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        3:18 PM
        So I'm a little confused;
        We went from rough running engine to no ELECTRICAL POWER did we?
        As in does not even crank over?
        If everything reads 1.0 on your meter, then either;
        it's on the wrong scale,or
        on the wrong setting,or
        the leads are in the wrong holes,or
        you are using it wrong,or
        the battery juice never made it to the circuit you are testing, or
        it's just not working at all, else it would read something different on every circuit.
      • MOPAROFFICIAL
        2,925
        1925
        Jun 1, 2016
        breakwater
        Local Time:
        1:18 PM
        My post was a general "if these things work, then it's.."
        I know how it works.
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        14,012
        2092
        Jan 16, 2005
        las vegas
        Local Time:
        1:18 PM
        check the bulkhead wiring ...had same problem with 73 Duster....the 3 plugs on the firewall....they will corrode ....wiggle the plug everything worked....wiggle again and everything is dead..
      • dartley
        dartley Well-Known Member
        459
        13
        Jun 21, 2006
        NY
        Local Time:
        4:18 PM
        If you had no headlights or dome light that has nothing to do with your ignition or ignition system. There is something wrong with your battery or wiring. If you try to jump start the car and you get the same result then your wiring is faulty.
      • Dodge73Dart
        Dodge73Dart Donar car
        144
        54
        Oct 13, 2008
        Western North Carolina
        Local Time:
        4:18 PM
        Is your amp meter working?
        Check the connections on it. Common problem.
