Ordered a gear vendor, help with deciding gears
Mopar General Discussions
  1. RogerCox
    RogerCox Well-Known Member
    131
    28
    Sep 30, 2020
    Visalia Ca
    Local Time:
    1:56 AM
    Ordered a gear vendor today, was told to go 3:55 gears, but I was thinking higher since I was originally going to go 3:23 without gear vendor.
    1974 duster
    Blueprint 408 stroker (465hp,550ftlb)
    Dana 60
    will be doing more street driving that track. Tires will be cobra Gt 295’s, but will also have a set of 315 nitto Nt05’s.
    Want it to have great acceleration to keep up with modern sports cars on the street, but not be too geared up that the pedal is so sensitive it becomes not fun to drive
  2. d1970
    d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
    463
    298
    Sep 29, 2015
    Ontario, Canada
    Local Time:
    3:56 AM
    a friends car has a gear vendor, his car runs at 2300 rpm at 70 mph using 3.73 gears and a 28 inch tire very nice setup.
  3. rumblefish360
    rumblefish360 I have escaped the evil Empire State! FABO Gold Member
    44,120
    16283
    Jun 21, 2005
    Florida
    Local Time:
    4:56 AM
  4. Joey4speed
    Joey4speed FABO Gold Member FABO Gold Member
    1,927
    1687
    Jul 17, 2018
    Coastal NC
    Local Time:
    4:56 AM
    Nothing to with gear vendor...
    originally had 3:91s
    Now I have 3:55s
    And still need to keep to right on the highway.
    But staying away from 3:23s, if I want to chirp around town.
  5. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    88,216
    71332
    Jun 7, 2010
    Georgia
    Local Time:
    4:56 AM
    I think those units are stupid. Like a passing fad.
    • Like Like x 1
    • Joey4speed
      1,927
      1687
      Jul 17, 2018
      Coastal NC
      Local Time:
      4:56 AM
      Rusty, you need to speak your mind, stop holding back!:poke:
      • Like Like x 1
      • Thanks! Thanks! x 1
      • toolmanmike
        toolmanmike Moderator Staff Member FABO Gold Member
        68,636
        62051
        Jan 18, 2006
        Iowa
        Local Time:
        3:56 AM
        One thing to consider with a overdrive (GV or transmission) is your cruise rpm in relation to your cam power band and torque converter. Too low of a cruise rpm with to radical of a cam and/or high stall converter and you have issues.
        • Agree Agree x 2
        • Like Like x 1
        • toolmanmike
          68,636
          62051
          Jan 18, 2006
          Iowa
          Local Time:
          3:56 AM
          :rofl::rofl:
        • RogerCox
          131
          28
          Sep 30, 2020
          Visalia Ca
          Local Time:
          1:56 AM
          haha I hope I didn’t make a stupid purchase. Makes sense to me to split 2nd and 3rd gear, have more range in the power band, higher gear for more acceleration and the OD to drop rpm ~600 on the highway.
        • toolmanmike
          68,636
          62051
          Jan 18, 2006
          Iowa
          Local Time:
          3:56 AM
        • RogerCox
          131
          28
          Sep 30, 2020
          Visalia Ca
          Local Time:
          1:56 AM
          engine is blueprint engines 408 stroker with hydraulic cams matched to there built 727.
        • rumblefish360
          44,120
          16283
          Jun 21, 2005
          Florida
          Local Time:
          4:56 AM
          I can reason out and mathematically prove how a GV is an advantage. In the real world, I have zero experience, in my head, I think about it all and I can not find a single reason to purchase or use one. IMO, it is not cost effective. My wallet is to thin to play with one. I myself would rather use a factory 4spd auto or a manual trans that has a OD gear, be it a A-833 or Tremac variant.
          BUT! This is just me.
          Did YOU make a big MISTAKE?
          IMO, I don’t think so since you thought about it and decided to make the leap. Your reasoning was sound in your head, go for it. And enjoy it! I called out to AJ/FormS because he has one and loves it.
          AJ is a good man and a solid dude that will help you out.
          He gets my stamp of approval and a big thumbs up.
        • RogerCox
          131
          28
          Sep 30, 2020
          Visalia Ca
          Local Time:
          1:56 AM
          Appreciate that! Would like to get this build right the first time without taking the Dana 60 out again to change gears haha.
          yeah originally I was going to do a 4L80e built trans by Jake’s performance m, but didn’t want to cut up my tunnel that bad and Blueprint Warrenty covered there engine and 727 trans. When I put my nitto 325 tires in I’d like to have a high gear and get those tires to hook for some serious acceleration.
          so guess I’m stuck with deciding 3:55, 3:73 or 4:10 gears.
        • toolmanmike
          68,636
          62051
          Jan 18, 2006
          Iowa
          Local Time:
          3:56 AM
          Which tells us nothing. You will need to dig up the engine and cam specs for when AJ shows up. Also rear tire size you are going to run. It all comes into play.
        • toolmanmike
          68,636
          62051
          Jan 18, 2006
          Iowa
          Local Time:
          3:56 AM
          A4l80 is a overbuilt waste of money for a small block stroker. Good thing you didn't go that route.
          • Like Like x 1
          • rumblefish360
            44,120
            16283
            Jun 21, 2005
            Florida
            Local Time:
            4:56 AM
            The GM trans from what I remember doesn’t require cutting up the tunnel. BUT.....
            The required parts to swap it in and associated parts to modify (IE; driveshaft) make the swap expensive vs a factory OD or other manual transmission “kits” that do the same thing.
            What is the final OD ratio of the transmission?
            Size of engine and the cam specs?
          • toolmanmike
            68,636
            62051
            Jan 18, 2006
            Iowa
            Local Time:
            3:56 AM
            The 4l60 and 4l80 does. (350 and 400 turbo's are quite large.) The 200's don't but they are weaker than our 904's unless you build he heck out of them. A street stroker would work fine with a 904 overdrive that has been purposely built.
            • rumblefish360
              44,120
              16283
              Jun 21, 2005
              Florida
              Local Time:
              4:56 AM
              Thanks Mike!
              • Like Like x 1
              • toolmanmike
                68,636
                62051
                Jan 18, 2006
                Iowa
                Local Time:
                3:56 AM
                Just for comparison, I had a 4l80E in my diesel powered tool truck. 18,000# GVW. Way overkill for a small block Mopar.
                • Agree Agree x 1
                • RustyRatRod
                  88,216
                  71332
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  4:56 AM
                  I'm going on what some people here have reported and the fact that the GV doesn't have "that good" of an OD ratio on paper. There have been a number of people on here through the years disappointed with them. For 3K dollars, you ought not to have to modify the floor, either. JMO
                  • Like Like x 1
                  • RogerCox
                    131
                    28
                    Sep 30, 2020
                    Visalia Ca
                    Local Time:
                    1:56 AM
                  • rumblefish360
                    44,120
                    16283
                    Jun 21, 2005
                    Florida
                    Local Time:
                    4:56 AM
                    Depends on the OD’s ratio and rear ends gear ratio.
                    Using an OD trans, 4 or 5 spd is IMO, a good idea. YOU just have to figure out what you want your cruise speed to be and at what MPH. Which works in conjunction with your tire size. This equation should work well with your cam.
                  • RogerCox
                    131
                    28
                    Sep 30, 2020
                    Visalia Ca
                    Local Time:
                    1:56 AM
                    what do you mean cruise speed? Like highway cruise speed. If so 70-72mph.
                    I originally ordered it (late Friday) because I wanted to run high gears like 3:73 or 4:10, and thought if I had a hood nitto 325 tire and could get it to stick I could have a hell of a launch.
                  • rumblefish360
                    44,120
                    16283
                    Jun 21, 2005
                    Florida
                    Local Time:
                    4:56 AM
                    Yes
                    So, third time! What is the OD ratio? What is the tire size. Please don’t list “Nitto 325....” give me the actual tire diameter.
                    • Agree Agree x 2
                    • DesertRat
                      DesertRat Leading edge boomer
                      3,206
                      3014
                      Jan 22, 2005
                      Moses Lake, Washington
                      Local Time:
                      1:56 AM
                      I have the GV unit with 3:73 gears and 28" tires . 2300 rpm@ 70 MPH. I like it, it's like having a 4speed.
                      • Like Like x 2
