Organic clutch disc for Centerforce pressure plate
Which clutch disc
  • Ram 203
    Votes: 0 0.0%
  • Mcleod M260120
    Votes: 0 0.0%
  • Centerforce 383269
    Votes: 1 100.0%
  • Other (do tell)
    Votes: 0 0.0%
  • Total voters
    1
Professor Fate
Push the button, Max...
Wisconsin
Is this the flywheel you plan to use? It's the only one I could find in 440Source's catalog.
1045 Billet Steel Flywheel - New-440 Source
Note that it is for INTERNAL (neutral) balance engines only. A 5.9 Magnum is external balance. And different from the LA360's external balance, too. Get ready for some nasty vibrations.
If you've already got the flywheel, there's several ways to address this.
1.) Return it or sell it and get the correct flywheel.
SCIENCE FRICTION Billet Steel Flywheel, SFI Quality, 130t/10.5", 360 Magnum, 6-bolt - American Powertrain , among others.
2.) Take the flywheel to the machine shop and have it rebalanced for the 5.9 Magnum.
3.) Get add-on weight kits
Bolt on Flywheel Weight for 130t Ext. Balance 360 Magnum Mopar Dodge A833 5.9 | eBay
I believe Quicktime also makes a balance plate that sandwiches between the crank flange and flywheel.
skep419
Comparison is the thief of joy
Minesoooota
I've already got the flywheel and the Weight you shared off ebay :thumbsup:
