Original AM Radio wires
Electrical and Ignition
  1. TF360
    TF360 Well-Known Member
    1,201
    298
    Apr 25, 2014
    Florida
    Local Time:
    11:03 AM
    On my original 1974 radio there are just two wires a red and a orange. I assume red is + power, but what is orange?
  2. 67Dart273
    67Dart273 Well-Known Member
    39,262
    6914
    Oct 14, 2010
    Idaho
    Local Time:
    8:03 AM
    Orange in Mopars is dash dimmer controlled lighting. Same as your dash lights.
    • Agree Agree x 3
    • Thanks! Thanks! x 1
    • TF360
      1,201
      298
      Apr 25, 2014
      Florida
      Local Time:
      11:03 AM
      67 thanks. I'm installing a aftermarket radio, so I won't need the orange for anything right- just tape it off?
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      49,363
      17305
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      11:03 AM
      Might go to the after market yellow or orange if it has a dimmer feature.
      • 67Dart273
        39,262
        6914
        Oct 14, 2010
        Idaho
        Local Time:
        8:03 AM
        Depends.......many aftermarket radios have a separate wire for the dash lamp just like your original. If not yes, tape it off. Put it in back of your mind, IE you install an accessory gauge panel, there is your lighting tap.
        • Murray
          Murray FABO Gold Member FABO Gold Member
          922
          479
          Apr 19, 2010
          San Jose, California
          Local Time:
          8:03 AM
          If a radio has a separate light wire- then it is tied into dash lights and will dim. If a radio has no separate light wire- then the light in the radio goes on with the radio and is not dimmable.
          • TF360
            1,201
            298
            Apr 25, 2014
            Florida
            Local Time:
            11:03 AM
            Ok, so the aftermarket radio (older am/fm cassette) has a yellow wire that shows it going to a positive separate from the red. It does not say dimmer, but I guess it will go to the orange-right?
          • 67Dart273
            39,262
            6914
            Oct 14, 2010
            Idaho
            Local Time:
            8:03 AM
            I would just try it...........hook it to a source and see if the light comes on LOL
