Original Big Block Mount Question
684door
Pittsburgh
I have an original K Frame and mounts. My 383 has the two treaded holes on the drivers side to accept the mount. My question is : What size bolt , thread pitch, and bolt length (length under bolt head) are the two bolts that thread onto the block?
Thanks
No idea on the length. I have a block that was drilled/tapped, but used conventional motor mounts.
Thanks
Thread a bolt in there and see.
