Yup, just turn counterclockwise until they loosen. Great advice above about measuring the floor to fender lip and counting the number of turns. I replaced my bars and had to adjust, lower the car, measure to make sure both sides were the same, raise the car, adjust, lower the car, measure, again and again until I was satisfied.
I sprayed my with PB Blaster for several days prior. In fact, I sprayed every nut that was coming out.
You have to slide the torsion bars back enough to get the lower control arm pivot pin out of the k-frame. I used slip joint pliers to remove the torsion bar retaining clips. I was very fortunate that my torsion bars came out with a good tug using both hands. You can slide them back about 6" to allow room for the lower control arm to come out.
