Over-center spring install question...
Manual Transmission & Clutch Discussions
  1. frederick_76
    frederick_76 Well-Known Member
    748
    170
    May 2, 2010
    Milton, Wa.
    Local Time:
    3:01 AM
    Do i just push pull and pry this thing on, or do I have some parts that are not right? The pedal brkt is the stock one from my 69 Valiant auto. No idea what the pedals or the spring came off of....
    Thanks, Dennis...
    [​IMG]
    [​IMG]
    [​IMG]
  2. Brad4406
    Brad4406 FABO Gold Member FABO Gold Member
    2,054
    297
    Apr 20, 2008
    Fairborn, OH
    Local Time:
    6:01 AM
    Looks right to me; you just need to get it hooked onto that post.
  3. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,264
    8710
    Mar 11, 2011
    Arizona
    Local Time:
    3:01 AM
    Put a large flat screwdriver through the spring end and the tip of the screwdriver over the top of the stud and lever it on there.
    I've done it that way probably 50 times.
  4. Coronet 500
    Coronet 500 Well-Known Member
    434
    90
    Dec 24, 2011
    Ontario Canada
    Local Time:
    6:01 AM
    Put one end of the spring in a vice, bend it over and add flat washers between the open coils then repeat other side until you have enough length to slip over. Clamp bracket in vice or bolt in car, depress pedal and the washers fall out.
  5. dodge71demon
    dodge71demon Well-Known Member
    3,323
    485
    Apr 29, 2009
    Indiana
    Local Time:
    6:01 AM
    Brilliant
  6. Coronet 500
    434
    90
    Dec 24, 2011
    Ontario Canada
    Local Time:
    6:01 AM
    The only brilliant thing I've done lately is to help my 22yr old son buy his 71 Demon. But thanks.
  7. Russ H
    Russ H Well-Known Member
    401
    4
    Mar 27, 2005
    Western New York, Cattaraugus County
    Local Time:
    11:01 AM
    Dennis,
    What type of pressure plate are you using? If it is a diaphragm type, leave the spring off.
    Russ
  8. frederick_76
    748
    170
    May 2, 2010
    Milton, Wa.
    Local Time:
    3:01 AM
    I am using a Centerforce part number DF 269675. With an American Powertrain hydraulic conversation kit. No Z bar and no clutch fork....
  9. Russ H
    401
    4
    Mar 27, 2005
    Local Time:
    11:01 AM
    Frederick,
    I am assuming that your Centerforce Clutch is a diaphragm type. If this is the case, Centerforce has always recommended that the over center spring be removed. Being that you are using a hydraulic throw out bearing, I would call Centerforce's tech line to be sure.
    Russ
  10. 1970duster360
    1970duster360 Well-Known Member
    110
    0
    Feb 20, 2008
    moonachie nj
    Local Time:
    5:01 AM
    leace spring off and get a lighter spring like one one scrren door
  11. Bob Dawson
    Bob Dawson New Member
    4
    0
    Mar 13, 2013
    Painesville Ohio
    Local Time:
    5:01 AM
    Can anyone tell me what I have here?
  12. Russ H
    401
    4
    Mar 27, 2005
    Local Time:
    11:01 AM
    Bob,
    Was there supposed to be a picture? If so, try again.
  13. daliant
    daliant Befuddled
    1,687
    143
    Jan 3, 2010
    Lockport,NY
    Local Time:
    6:01 AM
    It looks like a little picture of a mountain with a white line through it with a cloud above it on a piece of paper with one corner partially folded over.
    Yer pitcher didn't show up.
  14. frederick_76
    748
    170
    May 2, 2010
    Milton, Wa.
    Local Time:
    3:01 AM
    Turns out I don't need the spring. Lots of good ideas on how to put one in. Thanks anyways.....:eek:ops:
  15. daliant
    daliant Befuddled
    1,687
    143
    Jan 3, 2010
    Lockport,NY
    Local Time:
    6:01 AM
    Looks like a 70-72 A body pedal set up.
  16. Bob Dawson
    4
    0
    Mar 13, 2013
    Painesville Ohio
    Local Time:
    5:01 AM
    It is out of a 70 340 Duster I bought last year. The clutch released high and stuck a lot. It had some bogus return spring under the dash that was an add on and didnt work. After reading this blog we pulled it last night. The clutch "latch"(?) is really bent up. We thought it looked like an assembly out of a 318 or 6cyl as shown elsewhere in this blog but it has the heavier 340 spring! What do you think? Doi you think it can be straightened, cleaned up and salavaged? Also, do you know where I cab get the bushing that goes on the pedal end of the Z-bar? Thanks.
  17. duster360
    3,871
    357
    Aug 8, 2008
    Alabama
    Local Time:
    5:01 AM
  18. Bob Dawson
    4
    0
    Mar 13, 2013
    Painesville Ohio
    Local Time:
    5:01 AM
    Thanks. No comment on salvaing the pedal assembly?
  19. Russ H
    401
    4
    Mar 27, 2005
    Local Time:
    11:01 AM
    You should be able to replace the clutch pedal provided the frame itself is not bent. My suggestion would be to replace that entire pedal assemble with a heavy duty (340/383 type). I see them for sale here on FABO all the time. Check with Barracuda Kid (aka Eddie Combs,) I'll bet he has a good set .
    Russ
