jim in seattle
69 barracuda. Yes I have read all the threads I can find on here. I have about 50 hours into this one and am at the end of my patience! Here is what I know:
charges at 16V+ at idle
new alternator (schucks), battery, regulator (napa), battery cables.
cleaned all rust /paint at battery ground to engine, regulator to chassis.
also have tried grounding alternator and regulator directly to battery, and chassis to battery direct ground
keeping mulitmeter neg at battery ground, I find high voltage (16+) while iding at:
-input to regulator
-alternator (dark blue wire that is activated by key)
-battery positive
I also get same readings using the alternator casing and regulator casing as the ground for these checks.
wtf?
-input to regulator
-battery positive
wtf?
