Over heating on the freeway?
Heating / Cooling / AC
  1. j par
    j par Well-hung Member
    11,201
    4185
    Jul 2, 2014
    Portland Oregon
    Local Time:
    1:29 AM
    I'm fixing to break that new cam Grind on my car and I got a new radiator and I'm thinking of going without the Shroud also and just fixing the 2 electric fans just to the new radiator it's self.
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,541
    612
    Jul 16, 2017
    Northern Colorado
    Local Time:
    2:29 AM
    Why not use a thermostat?
    • Agree Agree x 1
    • Cope
      Cope Fusing with fire
      2,445
      1838
      Oct 20, 2009
      San Jose, Ca.
      Local Time:
      3:29 AM
      Because race car....
      We dont run T stats on the drag cars. That way we can cool them off easy with just the fan running. Cycle the water pump or bump the starter over, move water and continue cooling.
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      24,952
      4261
      Aug 28, 2009
      Ontario
      Local Time:
      3:29 AM
      What's the benefit of the restrictor plate?
    • Cope
      2,445
      1838
      Oct 20, 2009
      San Jose, Ca.
      Local Time:
      3:29 AM
      This way I never have to worry about a bad T stat. Water is moving. I can keep water in the radiator, run the fan and then bump the engine with ignition off or just turn on the water pump and move hot water out of the block into the radiator and start cooling water again.
      • Thanks! Thanks! x 1
      • Cope
        2,445
        1838
        Oct 20, 2009
        San Jose, Ca.
        Local Time:
        3:29 AM
        A thermostat ONLY heats the water and it dam sure can fail.
        I dont care how long it takes to warm up the water, I only care about keeping the water at the temp I want it at.
        190-210 degrees.
      • Dana67Dart
        1,541
        612
        Jul 16, 2017
        Northern Colorado
        Local Time:
        2:29 AM
        IMHO... easy test. leave radiator the way it is. swap restriction plate for 180 190 thermostat and test. restriction plate may be flowing way too fast to transfer heat at speed.
      • jobrated52
        jobrated52 Active Member
        32
        1
        Jun 30, 2006
        San Jose
        Local Time:
        1:29 AM
        Lower radiator hose could be collapsing. Had a similar problem.
      • Cope
        2,445
        1838
        Oct 20, 2009
        San Jose, Ca.
        Local Time:
        3:29 AM
        Spring in lower radiator hose.
        And with the plate in the T stat location I can check water flow at any RPM.
      • famous bob
        famous bob mopar misfit
        11,233
        2783
        Aug 14, 2011
        okla
        Local Time:
        3:29 AM
        I know a prof. mech. that cured an overheating problem on a blown chevette by using a plate w/ a 1" hole in it. I experimented w/ hole size on a hot 406sbc, and wound up w/ a 5/8" hole in it.--jfyai
      • 4spdragtop
        24,952
        4261
        Aug 28, 2009
        Ontario
        Local Time:
        3:29 AM
        :popcorn:
      • RAT ROD AL
        RAT ROD AL FABO Gold Member FABO Gold Member
        904
        661
        Jan 18, 2013
        St. James City. FL.
        Local Time:
        4:29 AM
        Cope , after reading through all the replies and ideas and seeing your shroud set up, I have come to the conclusion ( my own Opinion) . That some of us have no Idea what we are doing and some know every thing about everything!. In my past experience I have never had any problems with my car running to cool (except in the winter and getting not enough heat from the heater). I like to run all my hot rod , race engines and even my damn /6 van cool as possible. The engine will run up to the temp it likes, provided the cooling system is adequate. I have had to just throw out the thermostat on one to keep it from over heating, that some say you can't do that. I have never F ed up an engine by running to cool, Too hot your sitting on side of the road like old faithful at best. Now after seeing your shroud setup If every thing else is in good shape looks to be one sided. But I'm with Steve on this one , The first (cheapest) thing I would try is a lower T stat. Before tearing apart your shroud. Besides cooler engine= cooler oil. But with all that said I'm probably wrong again. Damn it.
        • Like Like x 1
        • Cope
          2,445
          1838
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          3:29 AM
          Pulled the rad and removed the shroud. Now it's fine on the freeway but it can no longer idle indefinitely.
          That just tells me I need a better shroud design or better fans (fan).
          Also I no longer have any breaklights, not related I know but annoying just the same...
          Thanks for the help.
