1. Spazz
    Spazz New Member
    4
    0
    Apr 7, 2014
    Cranbrook
    Local Time:
    11:09 PM
    ! have what I believe is a 74 440 in my Duster and it is always hot 220++
    Should I be using a 185f or 185F skirted thermostat ? OR is there something that I'm not seeing. I have looked at a lot of things and nothing helps. I don't think I could buy 4 bad thermostats in row. thanks
  2. /72Scamp
    /72Scamp Well-Known Member
    226
    49
    Jan 20, 2015
    Hampton NH
    Local Time:
    12:09 AM
    What type of fan are you using? And shroud or no shroud?
  3. Spazz
    Spazz New Member
    4
    0
    Apr 7, 2014
    Cranbrook
    Local Time:
    11:09 PM
  4. Spazz
    Spazz New Member
    4
    0
    Apr 7, 2014
    Cranbrook
    Local Time:
    11:09 PM
    16 inch on the outside (electric pusher, not so good) no shroud. Hoping to change all this to dual fans with shroud inside soon
  5. 1968FormulaS340
    1968FormulaS340 Well-Known Member
    11,394
    497
    Aug 24, 2005
    St. Helens Oregon
    Local Time:
    10:09 PM
    That's your problem.
    A thermostat change won't do any good. You are running 220. At 220 every thermostat out there will be open, if it's not, it's bad.
    The #1 problem with cooling systems is that people building bad cooling systems.
    • Agree Agree x 3
    • Thanks! Thanks! x 1
    • zigs
      zigs Well-Known Member
      2,603
      642
      Apr 10, 2010
      Yakima, Washington
      Local Time:
      10:09 PM
      I just changed. I had an under powered puller. I just bought a Ford Taurus fan. Do a thread search on Taurus fans.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        22,059
        9226
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        12:09 AM
        220Plus, on the gauge or 220+ using an IR gun to find the hottest part of the cooling system, usually just under the stat?
        220Plus idling in gear in traffic, or 220 screaming down the the hiway at 4000 rpm, or 220Plus at 35 mph in Drive. Each of these requires a different solution. Or I could give you a recipe to cover all of them, but you won't like me much.
        • Like Like x 1
