1. AKrum
    AKrum New Member
    4
    0
    Aug 25, 2021
    Alabama
    Local Time:
    8:52 AM
    I’m having issues with my clutch pedal returning all the way. Upon further inspection the over center is rubbing on a bracket. I’m not sure if the spring is on correct for that matter. Still haven’t ruled out other issues in the clutch linkage but it shifts fine. Any help is appreciated.
  2. Jeremiah
    Jeremiah Well-Known Member
    129
    75
    Oct 2, 2013
    Rogue River, OR
    Local Time:
    6:52 AM
    You either have a worn bearing/bushing in the pedal pivot shaft assembly of there is something misaligned in the clutch linkage driving the pedal over. For whatever reason the a body pedals are not nearly as beefy as the b body stull and folds easily.
    Carefully check alignment of the clutch linkage below while a helper activated the pedal.
    (with the wheels blocked if you are on an uneven surface lol)
    • Agree Agree x 1
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      7,314
      4962
      Jul 16, 2017
      Northern Colorado
      Local Time:
      7:52 AM
      You could pull the spring out and see if thete is a lot of play.
      Intresting spring removal methoud i recently found out about...
      Take washers or other relatively thick pieces that you can get in there and with spring stretched during pedal application put the shims between the spring coils. Release the pedal and the spring will be loose.
      Dont know what thickness or how many would be needed to spread the spring enough to remove it.
      Stumbled on this photo mopp_1012_08_o-four_speed_a_body_clutch_pedal_adjustment-over_center_spring.jpg
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      2,288
      1922
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      9:52 AM
      Wow! That s an awesome trick. I wish I learned that years ago before I lost that finger. Lol!
      • Like Like x 1
      • Agree Agree x 1
      • Oldmanmopar
        Oldmanmopar Going left turning right FABO Gold Member
        9,308
        6014
        Jan 8, 2009
        Danielsville Pa. 18038
        Local Time:
        9:52 AM
      • Oldmanmopar
        9,308
        6014
        Jan 8, 2009
        Local Time:
        9:52 AM
        I have a pedal assembly like yours with that brace, It is 6 inch. It came from a 68 Dart GTS
      • jos51700
        jos51700 Green Bearing thread connoisseur
        5,854
        2635
        May 24, 2009
        Bel-Ray
        Local Time:
        8:52 AM
        Is the pedal bracket from a stick shift car? They had a little brace on them that automatic cars don't have. If you use the clutch pedal with the auto bracket, the bracket will deflect and the spring will drag. I found that out when I converted mine.
        • Like Like x 1
        • AKrum
          AKrum New Member
          4
          0
          Aug 25, 2021
          Alabama
          Local Time:
          8:52 AM
          That is probably it. Thanks for that!
        • Daves69
          Daves69 Well-Known Member
          5,937
          4383
          Feb 20, 2011
          WestOfChi
          Local Time:
          8:52 AM
          Maybe this can help. '69 hd pedal. Has been in the car as long as I've had it.
        • AKrum
          AKrum New Member
          4
          0
          Aug 25, 2021
          Alabama
          Local Time:
          8:52 AM
          Looks like you have more clearance between the bracket and OC spring closest to the firewall. I’m wondering if I just bend that bracket slightly off the spring if it would fix it.
        • Johnny Dart
          Johnny Dart Well-Known Member
          8,401
          3119
          Nov 30, 2006
          So Cal
          Local Time:
          6:52 AM
          Go to a diaphragm clutch, if it doesn't already have it.
          Take the over center spring off, and give it to your neighbor.
          The clutch is soooo much smoother without it.
          • Agree Agree x 2
          • CRUZE 418
            CRUZE 418 FABO Gold Member FABO Gold Member
            878
            368
            Mar 11, 2019
            Illinois
            Local Time:
            8:52 AM
            The washers work, but it's easier to just remove the steering column and take the whole thing out. The spring is easy then, but thats just me. Make sure all of the geometry is correct from inside the car all the way into the bellhousing.
          • Daves69
            5,937
            4383
            Feb 20, 2011
            WestOfChi
            Local Time:
            8:52 AM
            "Make sure all of the geometry is correct from inside the car all the way into the bellhousing.
            As CRUZE points out, it's the first thing you do.
            Secondly, have another person work the pedal slowly as you watch the linkage motion all the way into the release bearing.
            Possibly, I guess...... but I'm thinking a spring with that amount of pressure isn't going to let that bracket stop it.
            Looks like the spring is fully collapsed in your picture. Is your pedal down some (off) the peddle stop at that point? When the pedal is full up to the stop, does the spring feel loose on the pins like it's too long?
          • CRUZE 418
            878
            368
            Mar 11, 2019
            Illinois
            Local Time:
            8:52 AM
            Also, you shouldn't need that other spring, seen in your picture. . The spring from the clutch to bellhousing determines your free play. Pedals aren't always even, my clutch pedal sits below the brake pedal. After checking geometry, it wouldn't be a bad idea to take that pedal cage out and go through it, its 52 years old. Bead blast, paint, maybe new bushings and grease.
            I can talk you through the easy way to remove and install the spring. Or, you can do the washer thing.
