Overheating -- Corrective measure questions.
Heating / Cooling / AC
  1. Kent mosby
    Kent mosby FABO Gold Member FABO Gold Member
    915
    847
    Aug 24, 2018
    Idaho
    Local Time:
    6:01 PM
    I have just read the rather lengthy and well detailed thread on overheating and yet I still have some questions and did not want to hijack that thread.
    I have a 1973 plymouth scamp with a 512 that always ran under 200* while moving. This past weekend I went to a car show Car d'Lane and during the Friday cruise it was 90*. The cruise was more of a crawl. In about 30 minutes I travelled maybe a mile. My temp steadily climbed to 251* according to the sniper readout. Nothing blew and I pulled off the route. As soon as I got it on the road at about 35 mph it dropped to 205 within a couple miles. I obviously need to correct this issue asap.
    My cooling specs are.
    180* Mr. Gasket 4367 high flow, high performance thermostat
    Mopar 7 blade fan. crank to fan pulley ratio,, .95:1
    Griffin performance 8-00038 26.5x18 2 row with 1.25 inch tubes
    3871088 mopar 8 blade water pump.
    7 psi radiator cap
    Shroud, Homemade by me but looks appropriate,,, let me know
    There is a 10x12 inch trans cooler in front of the radiator.
    Since the radiator cools appropriately when the car is moving and at the race track, I assume that I have enough radiator but not enough coolant and/or air flow at low speed or idle. Correct???
    Now for the corrective measures. Our race track closed so I do not need a cooling system for that purpose. I am now making the car a street/show driver. Slow speed cooling is a must.
    My thoughts to improve things are that I could overdrive the water pump by changing pulleys?? And/or get a different one but this one is supposed to be good.
    I could switch to electric fans controlled by the sniper efi but that would require that I change the alternator to a 90 amp from 60 and I would have to change the radiator as this one is 3 inches thick and it sticks out from the core support by an inch leaving only 2 inches from the water pump pulley to core.
    I could get an electric water pump that may save some space. In AndyF's book he states that the electric pumps are ok for racing but will not keep up for street use. Any experience on this? Good or bad idea?
    I could change the thermostat to a 160 milodon high flow model.
    Anyone use a pusher fan in addition to this setup for street use??
    I tried to gather as much info as possible before posting but I may have missed something. What would you do to correct the slow speed cooling issue? IMG-0730.jpg IMG-0731.jpg IMG-0883.jpg IMG-1251.jpg IMG-0838 (1).jpg
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      79,150
      57448
      Jun 7, 2010
      Georgia
      Local Time:
      9:01 PM
      One thing I see that kinda jumps out is, you've introduced too much fan into the shroud. Generally, you're supposed to have about half the fan out of the shroud, maybe a little more. Yours is the opposite. Most of the fan is in the shroud. I would try a shorter spacer. You have the room from what it looks like to back the fan out some.
      The second thing I'd recommend is a Stewart high flow 160 thermostat. Getting as much flow as early as possible will help the engine from ever getting to "that point".
      I like that fan. Although it's not the five blade staggered fan, it is staggered. The MP engine book "says" the five blade staggered fan moves more air, but I don't know if it moves more than THAT fan. If it does, it's splittin hairs. I think backing the fan off some and the cooler high flow thermostat will get it. Make sire it's a Stewart. They ain't cheap, but they're worth the extra money.
      • Agree Agree x 3
      • Thanks! Thanks! x 1
      • RustyRatRod
        79,150
        57448
        Jun 7, 2010
        Georgia
        Local Time:
        9:01 PM
        • Agree Agree x 2
        • d1970
          d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
          435
          256
          Sep 29, 2015
          Ontario, Canada
          Local Time:
          8:01 PM
          if the fan is too deep into the shroud it can cause turbulence affecting airflow and cooling ability.
          • Agree Agree x 3
          • Like Like x 1
          • RustyRatRod
            79,150
            57448
            Jun 7, 2010
            Georgia
            Local Time:
            9:01 PM
            Gettin rid of that GAWD AWFUL accordion upper hose will sure make it look better AND it will increase flow as well. 86 the bottom one too if you have one there. They look stupid anyway. Chevy stuff. lol No offense.
            • Agree Agree x 3
            • Kent mosby
              915
              847
              Aug 24, 2018
              Idaho
              Local Time:
              6:01 PM
              The only way to move the fan out of the shroud is to move the radiator forward. For some reason it has a 1" offset flange that sets it back from the core support by an inch. Would that be enough?
              Yea, that upper hose was a bandaid that stayed there. I have been meaning to replace it but have not found the correct one. There was not a 440 in a 73 scamp. Maybe I can look for one out of another model. Lower one is correct.
              • Like Like x 1
              • RustyRatRod
                79,150
                57448
                Jun 7, 2010
                Georgia
                Local Time:
                9:01 PM
                Use a thinner fan spacer and shorter bolts. Simple. For the hose, go to whatever local parts store you use and ask to go behind the counter and look for a molded hose that matches what you have. They'll let you do it unless they don't want your business anymore. lol
                • Agree Agree x 1
                • 12many
                  12many Well-Known Member
                  2,368
                  2902
                  Dec 14, 2016
                  SC
                  Local Time:
                  9:01 PM
                  An electric pump would likely (depending on model/gph rating etc) move the water faster at idle up to an rpm point better than the mechanical but then as your rpm’s increase the mechanical will move it faster as they all have higher gph ratings which you just can’t match with an electric. So you might have cooler running down low in stop and go traffic but as speeds and rpm’s increase you’d likely have hotter running temps. I saw about a 10-15 degree increase going from an 8 vane w/plate mechanical to a moroso electric. I put the mechanical back on, and am looking into an inline electrical pump for the lower hose to run at the track for between runs cooling.
                • AAndrews
                  AAndrews MOPAR .. Move Over, Plymouth Approaching Rapidly!
                  994
                  938
                  Nov 5, 2014
                  St. John's, Newfoundland, Canada
                  Local Time:
                  10:31 PM
                  A lot of good suggestions here..
                  One thing I noticed. You have a 10 x 12 inch aftermarket trans cooler mounted in front of the radiator? That's 120 square inches of air flow being partially blocked. If its a 26 " rad then almost half of it has an obstruction to airflow in front of it.
                  The factory did not do it this way, even for Hemi Cars! The rad had internal provisions for trans fluid cooling.
                  I'll be the first to say I'm speculating here but this stood out to me as a possible problem.
                  • Like Like x 1
                  • Agree Agree x 1
                  • Tooljunkie
                    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                    20,053
                    22172
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    8:01 PM
                    If its like my parts store, they have 2 hoses. For some reason rad hoses dont fail like they used to.
                    • Like Like x 1
                    • Agree Agree x 1
                    • ir3333
                      ir3333 Well-Known Member
                      5,075
                      1592
                      Jun 1, 2008
                      ontario,canada
                      Local Time:
                      8:01 PM
                      if you have a 7 psi rad cap you would have boiled over at ( 7x3 ) 21 plus 212 or 233 degrees so you weren't at 251 degrees. If you were at 251 i think it might have expanded and locked until cool.
                      I'd be suspicious at that that much change when it has been fine...try a new gauge
                      • Like Like x 1
                      • Kent mosby
                        915
                        847
                        Aug 24, 2018
                        Idaho
                        Local Time:
                        6:01 PM
                        I do not have any fan spacer at all on the pulley. The fan is touching the pulley.
                        • Like Like x 1
                        • Dana67Dart
                          Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
                          7,810
                          5426
                          Jul 16, 2017
                          Northern Colorado
                          Local Time:
                          7:01 PM
                          I don't know if this is even posable but back in the day when SB Ford's went from v belts to serp belts they did not change how the water pump bolted to the front of the engine they just changed the direction the impeller should rotate and the internal pathways for the coolant to travel.
                          Everything else would just bolt up, fan, pulley etc
                          If one bought a serp pump and put it on a v belt engine the pump would be run backwards. That would cause all kinds of issues
                        • yellow rose
                          yellow rose Overnight Sensation
                          28,501
                          25173
                          Jun 19, 2015
                          Central Washington
                          Local Time:
                          6:01 PM
                          You can NOT underdrive the pump that far. You have a kick ass radiator. As RRR said, you NEED a Flowkooler pump and some overdriven pulleys. And a Stewart Components thermostat. There is nothing like it on the market. These are the old Robert Shaw thermostats.
                          You’ve got most of what you need with the radiator. Now you need a couple of little thangs and you’ll be pooping in the tall cotton.
                          EDIT: I forgot to mention you need to throw the shroud away and use a spacer to get the fan about an inch away from the radiator. If you get it that close, you want need a shroud. It will be close enough to the radiator to pull plenty of air at idle (if you get the pump speed, and by mechanical connecting the fan speed up where it should be) to keep it cool at at high speeds the shroud won’t be packing air.
                          • Agree Agree x 1
                          • yellow rose
                            28,501
                            25173
                            Jun 19, 2015
                            Central Washington
                            Local Time:
                            6:01 PM
                            Like the Davies-Craig pump? Man those are way cool. I will get me one of those pumps with the controller and all of it. Then I won’t need the water pump.
                            • Like Like x 1
                            • RustyRatRod
                              79,150
                              57448
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              9:01 PM
                              I can just about 100% promise you there's a spacer there. Once they've been on a while, they kinda become "married".
                              • Like Like x 1
                              • Agree Agree x 1
                              • Kent mosby
                                915
                                847
                                Aug 24, 2018
                                Idaho
                                Local Time:
                                6:01 PM
                                new water pump and thermostat are on the way. I will remove the shroud and check out the pulleys tonight. Thank you for all the guidance.
                                • Like Like x 1
                                • Dubob
                                  Dubob Well-Known Member
                                  1,338
                                  593
                                  Oct 28, 2011
                                  Ohio
                                  Local Time:
                                  9:01 PM
                                  I use a 20630 gates for upper hose on my Demon.
                                  • superchargeddrt
                                    superchargeddrt Well-Known Member
                                    2,359
                                    959
                                    Aug 24, 2009
                                    Pittsburgh, Pa.
                                    Local Time:
                                    9:01 PM
                                    I have an electric fan (from a Chevy HHR) cooling my radiator. The radiator does not have a transmission cooler in it so I have combo trans/oil cooler sitting flat(no blocking the rad) with its own electric fan. I run about 190 degrees on my 418 stroker.
                                    Edited: Should have been 190° not 290°
                                    • Like Like x 1
                                    • furyus2
                                      furyus2 Well-Known Member
                                      2,266
                                      750
                                      Oct 30, 2010
                                      weeki wachee fl
                                      Local Time:
                                      9:01 PM
                                      What I noticed, was you don't have a hood seal. That keeps the air from going around the radiator, instead of through it. Also, if the radiator is too far from the core support, have the rad mounts cut off, and welded on in the proper place. This might put the rad where the shroud will work.
                                      • Agree Agree x 2
                                      • Like Like x 1
                                      • 12many
                                        2,368
                                        2902
                                        Dec 14, 2016
                                        SC
                                        Local Time:
                                        9:01 PM
                                        Before I settled on the Moroso I looked at those and there were two other versions that were mounted right off the bottom outlet but can’t recall the brands or exactly what the mounting setup was
                                      • Mike69cuda
                                        Mike69cuda 66 is the new 17 FABO Gold Member
                                        2,520
                                        2047
                                        Jan 2, 2018
                                        Overland Park Kansas
                                        Local Time:
                                        8:01 PM
                                        I just made the mistake of having the fan too far in the shroud. It really hurt my cooling. When I went 1/2 in 1/2 out it really made a difference.
                                        I have concluded that the fan and the shroud must be matched. I had an old fan that was designed for the 1/2 shroud. Didn’t work with a full shroud.
                                        I believe that if you have a fan designed for a full shroud, it would also help solve your problem. Most cars & trucks have the fan “all in” in the last 30 years. The fans are different shapes, but I am not smart enough to understand the difference.
                                      • RustyRatRod
                                        79,150
                                        57448
                                        Jun 7, 2010
                                        Georgia
                                        Local Time:
                                        9:01 PM
                                        Make sure you look at that fan REAL close. I have never in my life seen a fan spacer MADE onto a fan. First time for everything, but I just BET they are separate.
                                        • Agree Agree x 1
                                        • RustyRatRod
                                          79,150
                                          57448
                                          Jun 7, 2010
                                          Georgia
                                          Local Time:
                                          9:01 PM
                                          I think his shroud will be fine if he can get that fan back out of it some.
                                          • Agree Agree x 2
                                          • Garrett Ellison
                                            Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
                                            3,707
                                            2944
                                            Jan 1, 2018
                                            Southwest VA
                                            Local Time:
                                            9:01 PM
                                            Looks like a factory 17 inch fixed fan. Those move a lot of air. I've seen them cool a lot worse than that. Like mentioned, new water temp sensor for the sniper, smooth hoses off the radiator, Flow Kooler or PRW pump, and overdrive pulley set. What diameter is your bottom pulley?
