[WANTED] Package tray speaker grates
j061093409
1970 Dart Swinger 340 Reg
Wethersfield, CT
Looking for 2 door rear speaker grate (6x9) factory. Any body style should work. Will piece in to fix mine.
If you have a mint original 2 door tray with speaker grates & defroster slot, $200
Call/text 8604168434 in CT
The slotted panel you have is the speaker grate, it looks like someone may have added an aftermarket one at some point based on the screw hole damage?
Yes, it looks like the factory oval speaker bezel was added. I need either pieces to fix this one or find a mint one!
I have purchased one from REM & Legendary, both are smaller grates than factory & I cannot use them as I am looking for all original pieces on my 72 Canadian Special 340 Dart.
In the repros there are 2 different lengths. 1 for upholstery sides and another 1 for the plastic upholstery in the dusters, not sure if dart went to plastic interior.
Zero, zip, nada, factory oval bezel.
The package tray board itself was the grate, no extra parts on top.
