Paint Black Design on Hubcap
Tires and Wheels (Mopar Hubcaps Too)
  1. Lord Sparky
    Lord Sparky Well-Known Member
    69
    39
    Dec 2, 2019
    Carlsbad, California
    Local Time:
    4:43 AM
    Any ideas on an easy way to paint the black design on these Dodge Dart hubcaps? Should look like the part with the arrow. I thought about brushing with black enamel and using a cloth to wipe off the ridges.
  2. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    1,847
    1187
    Jun 16, 2017
    Maryland
    Local Time:
    7:43 AM
    I have to do the same to my cop wheel caps. The design is exactly like yours. I was thinking the same thing. Wipe the edges with a rag and acetone. Masking would make a hard line and wouldnt look right.
    • Like Like x 1
    • 4spdragtop
      4spdragtop Well-Known Member
      27,985
      7768
      Aug 28, 2009
      Wasting time here
      Local Time:
      6:43 AM
      By hand with freestanding magnifying glass
      • Like Like x 1
      • Agree Agree x 1
      • RedFish
        RedFish Well-Known Member
        23,788
        2504
        Sep 5, 2007
        Local Time:
        7:43 AM
        I haven't done this hubcap detail but have done fender badges and other similar parts.
        With a little masking ( or none ) you could spray paint it and wipe away the excess. I use a small piece of flat synthetic dress shirt type material wet with thinner laced between my fingers so only middle finger does the wiping. I recall whittling a pop cycle stick to a point and wetting it with thinner to get at some very small detail. Forgot what part that was.
        You must keep in mind that this sort of small detail wasn't absolutely perfect when the parts were brand new. Nobody looked at them close enough to notice imperfections. They might notice on the 4th or 5th time they washed their new car. Thus as good as new is doable.
        • Like Like x 2
        • pntastar69
          pntastar69 Well-Known Member
          1,448
          130
          Dec 28, 2006
          Gilbertsville, PA
          Local Time:
          9:43 AM
          I did it that way and wiped the excess as you mentioned.
          • Like Like x 1
          • CudaChick1968
            CudaChick1968 The Mistress of Metal FABO Gold Member FABO Vendor
            10,819
            3844
            Jan 17, 2005
            Greenfield, Tennessee
            Local Time:
            6:43 AM
            That's right up my alley! Though raised and recessed areas are treated differently in my industry, the color breaks/lines turn out sharp.
            • Like Like x 5
            • Bulldozer
              Bulldozer Well-Known Member
              15,383
              2004
              Oct 16, 2011
              why
              Local Time:
              6:43 AM
              I use a black enamel paint pen from the hobby store
              • Like Like x 1
              • Dicer
                Dicer Diceman FABO Gold Member
                961
                1257
                Jan 12, 2016
                Land of Lincoln
                Local Time:
                6:43 AM
                Found these touch up brushes at a local paint store and use some Testers paint and thinner. Mixed up the paint, dapped a little on and pushed the paint blob around with the tip, worked well..
                • Like Like x 1
                • Agree Agree x 1
                • demon67
                  demon67 Well-Known Member
                  45
                  5
                  Sep 25, 2011
                  cornwall
                  Local Time:
                  7:43 AM
                  First time doing this on my caps also. Do you wipe of the excess black paint with thinner when the paint is still wet?
                • pntastar69
                  1,448
                  130
                  Dec 28, 2006
                  Gilbertsville, PA
                  Local Time:
                  9:43 AM
                  I let the paint dry then wiped afterwards.
                • demon67
                  45
                  5
                  Sep 25, 2011
                  cornwall
                  Local Time:
                  7:43 AM
                  ok, awesome. Any prep before painting, like primer or anything else? I have original caps, no the repop's.
                • pntastar69
                  1,448
                  130
                  Dec 28, 2006
                  Gilbertsville, PA
                  Local Time:
                  9:43 AM
                  Clean n paint.
                  • Thanks! Thanks! x 1
                  • Lord Sparky
                    69
                    39
                    Dec 2, 2019
                    Local Time:
                    4:43 AM
                    I finally got around to touching up the hubcaps. Two did not need anything. One had chips in the black paint that I was able to touch up with a small brush. I did have to use a primer first, at the flat black Rust-Oleum paint would not stick at all to the metal. The black paint on the fourth hubcap was all completely loose so I had to remove it all with a wire brush. I decided that I had to mask the whole hubcap with some blue tape as a small brush and wiping technique did not work (I used to be a house painter, so I have a pretty steady hand). I had to slice off narrow 2-3mm strips with a razor blade. This took me about two hours and drove me to the brink of madness. There were almost 100 of the tiny masking strips. As I was doing it, I thought the results would be awful, but the results were better than I thought. Would I ever do this again?
                    • Like Like x 4
                    • MoparMike1974
                      1,847
                      1187
                      Jun 16, 2017
                      Maryland
                      Local Time:
                      7:43 AM
                      You can buy really thin masking tape. I believe you can get it as small as 1/8" wide.
                    • Lord Sparky
                      69
                      39
                      Dec 2, 2019
                      Local Time:
                      4:43 AM
                      Yes, that is definitely what I would recommend, but at the time I just dove right into it. 1/8 inch is a little too wide. I think there is some kind of graphics tape, but did not see this on Amazon.
                    • Dicer
                      961
                      1257
                      Jan 12, 2016
                      Land of Lincoln
                      Local Time:
                      6:43 AM
                      I have used this tape @ Lowes, Menards and Home Depot most always carries it. Lay the roll flat and use a razor to cut down the center of the roll and you will have the width you need to tape. Scotch 3M 08987 Performance Masking Tape 1/8" wide
                      • Like Like x 1
                      • A56
                        A56 MoParAffliction
                        503
                        328
                        Jun 24, 2014
                        White Oak, N.C.
                        Local Time:
                        6:43 AM
                        Take them to a nail salon, those women have a steady hand.
                        • Like Like x 1
