dartfreak75
Restore it, Dont part it!
Is the low voc stuff less harmful to us or just the environment?
Has anyone here ever used paint from www.paintforcars.com they have Alot of options as far as bc/cc single stage colors etc. I'm gonna get my primer from summit for sure I gotta decide on my paint lol I was just gonna get the single stage low voc stuff from summit but now im thinking maybe I should go with bc/cc
I have used it, it lays down nice.Has anyone tried the summit hs clear coat? Is it any count?
Thanks how long has it been on your ride? Has it held up good?I have used it, it lays down nice.
Thank you what are the 3 levels? I know you have lacquer enamel and urathane with the latter being the top but of the urathane what makes one better than the other?
Thank you for the info! In your opinion do you think summit hs clear is a good topcoat? I'm not talking show car quality paint job just an average OEM quality paint job that will protect for 10 years or more without fading or cracking?I was referring to top coat "durability" not technology types.
"Durability" includes weathering resistance, chip and abrasion resistance, color fastness, scratch resistance, gloss retention, and a host of others requirements.
There are 3 levels of paint manufactures, 5 counting the junk paint manufacturers. The top paint manufacturers sell off their off-spec intermediates (materials) to the lower tier paint manufacturers, the resin and additive manufacturers do the same, thus the lesser quality paint. The worst (scrap) materials get shipped to China and third world countries for various uses there. The lower the tier paint manufacturer the less quality can be expected. In short; You sometimes get what you pay for.
In a past life I managed 3 automotive paint development labs for a top tier paint manufacturer, one lab group evaluated OEM and Refinish materials. It's surprising what you find!!. Scary results sometimes too.
FYI - Do not confuse OEM top coats with refinish top coats, as they are completely different animals.
I still paint 1 or 2 vehicles a year for close friends and relatives only , just to keep my hand in it.
This weekend; I'm painting the wife's new bike (tank, fenders) with some House of Kolor candy red with Shimirin2 flake and a whole bunch of clear coat. Hand pin striping will closely follow.
Good luck with your project!
sscuda
Yes that does help thank you. Because I was considering using the urekem base from thecoatingstore with summit clear.Summit sells what is called a Tier 3 brand of topcoat. It's used by hobbyists because it applies well and is very forgiving for novice painters. I'm pretty sure it wasn't one of the paint brands that we evaluated so I can't comment on the quality. Summit buys their paint from one of the Tier 3 paint manufacturers, If I knew which one I may be able to answer your question.
One thing to take under consideration is don't mix the brands or technologies of coatings. Most coatings are designed to be a used in a "system", that is use the same prime , base, clear from a single manufacturer. Surface Tensions differ greatly between manufacturers and technologies. If the difference in surface tension is great you can encounter adhesion failures between the coating layers .
I hope this helps.
