Part Name
dodgedart1968
Amston, CT
This perished rubber part is near the upper ball joint, adjacent to the shock absorber. ('68 Dart). What is the part name?
Thx.
That and suspension stops or bump stops. You acn get new ones or if your altering you suspsneion (lowering) Many companies (Energy Suspension, Prothanre, etc) sell sifferent size and shapes. You lower control arms will have have them too, but are shaped differently. On newer cars these can be located inside the strut body.
you got it, the bullet ones are for upper control arms, and the rectangle ones with a ridge are for lower control arms. Rockauto also has pinion snubbers for the rear end under that same bump stop category.
That's bump stocks and no I don't think there illegal
No reason they should be illegal, but i am sure the "If it saves just 1 life" crowed will make it so at some point.
Update...
Bump Stocks | Bureau of Alcohol, Tobacco, Firearms and Explosives
ILLEGAL!
By the way, trump did it)
"On February 20, 2018, President Trump issued a memorandum instructing the Attorney General “to dedicate all available resources to… propose for notice and comment a rule banning all devices that turn legal weapons into machineguns"
Goes to show that you can not trust any politician!
Also
But in March 2021, the Sixth Circuit Court of Appeals struck down the ban on bump stocks, disagreeing with the ATF’s interpretation of the law. Despite the court order, the ATF’s website still characterizes the devices as machine guns.
