[SOLD] Parting out 68 notch carcass
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
This is the car I got a while back and stripped for the parts. The back half and floor is totally rotted out. The front has a lot of good sheet metal parts left on it.
Door jambs , cowl, front core support, Inner fender wells , fire wall all look ok. This carcass is headed the the scrap pile soon. So If you need a piece of it PM me . Pieces I will sell cheap
( basically for the cost of Blades , cut off wheels and Bandages and antibiotic ointment !)
The parts will be cheap but the shipping might not be. So keep that in mind before you want something and have me cut it and then change your mind. Reason being I will have to sacrifice one piece to save the other. ( I'M not a surgeon !)
So with that being said It will be 1ST come 1ST served
Thanks AL
How much for this piece. Mine is bent
from inner to inner
Is that the lower part of the radiator support ? And what do you mean "inner to inner"
Inner fender well,
Where it starts turning up. @ 4in or so i think
The inner fender wells are already claimed. Can you get me a better pic of what your wanting and description ?
Just where it turns up @ 4 in. or so. Can cut or drill spot wells .So i can install in my Form. S
Will look like factory
OK , I think. I will check it out in the AM as it's midnight here now. But I think it's in good shape. If so , FREE just pay shipping.
Do you want the lower horizontal part and the 2 bends where they bend up to the inner fenders ?
I might want other parts , so please give me a few days to check out my 68 Form S to be sure i dont need other metal. B4 u scrape shell
OK got some of the car cut up. Stripped out my saws-all, used up all my cut off wheels, plasma cutter crapped out, Can't find any more CRACK that I must have taken (joke) when I thought this deal up ! But so far only two wounds. Bought a new saw tonight ,to finish up the job come MON.
Thats easy part, hard part is fixing that weak part on my inner fender. Can u cut me out a section of ur parts car
