PCV/Breather
Valiant273
Active Member
Ottawa, Ontario, Canada
Hi Guys,
Just realized my 273 does not have a breather or PCV valve on either valve cover. I know, I know "you just noticed after 2 months?"
What the hell? Should they not have a least a breather on one cover?
A PCV valve on the right cover and a breather on the left cover would be the minimum I would accept. It can go up from there. Sounds like someone put aftermarket covers on your motor without due consideration----------------
DR--------------
Having neither is a sure way to create front/rear main seal leaks, or leaky valve covers...
Hi Guys,
OEM has PCV on one and a breather on the other.
Yep, and one in front and the other in the back is even better yet.
My PCV valve is in the rear of the left cover and filtered air comes in the front of the right side.
