seabee
Hi Gang,
I am about to install a pcv valve on new valve covers that came with my engine. Before I cut out the holes would like to ask your recommendation on a quality pcv valve, breather system.
318 with 302 heads (1.88/1.60 valves)
cam: Hydraulic
Intake Duration (gross): 256
Exhaust Duration (gross): 262
Intake Duration (.050”): 204
Exhaust Duration (.050”): 208
Intake Valve Lift*: .420"
Exhaust Valve Lift*: .420"
Holley 600cfm
manifolds/Accurate exhaust
Vacuum stays around 19 at idle
Thanks in advance and Happy Holidays,
Seabee
cam: Hydraulic
Holley 600cfm
Seabee
