Pedal gets hard half way down, little front brakes
Lvlrlvlopar
New Member
Albany
Hi I’m having some trouble with my car 1970 dart 4 wheel drum. I recently had the front end apart for about a month rebuilding it. The drums were off the whole time. Finally got it back together and now my front brakes don’t seem to be doing much. The rear tires lock up first and the pedal seems to get hard half way through travel. I readjusted the front shoes. Gave it a quick bleed at the wheel cylinders. And cracked the lines at the master loose. I did get a couple bubbles from the line going to the front brakes. But the only thing that helped any was re adjusting the shoes. Still locking up the rear tires and only slight nose dive and have hard pedal half way down. 12” vacuum at idle. Thought the hoses may have gotten collapsed internally but they seemed to bleed ok. Is it possible my master cylinder went bad while sitting? Or the hoses are bad but bleed ok? I was going to take the drums off next and check wheel cylinder movement. How much travel should I expect? Any other ideas?
Thank
Problem may be rear shoes wet from brake fluid leak or rear end 90w soaking them. That will cause the rear to lock up. You may want to look at front wheel cylinders, they may be cruded up and pistons not moving much.
this may not help you. i was stumped on why my front left drum keeps locking up. took it apart 3 times, replaced wheel cylinder and that didnt fixit. i think ive narroed it down to the brake hose being collapsed.
Swapped lines front/rear on the MC by any chance?
With 12" vacuum on the engine I would do an engine tune-up first. That's lousy vacuum and it's probably struggling to pull the booster for brake-assist.
With the cam that is in my Dart, the best I can so is 12" vacuum. But that has always been enough to operate my power brakes. Only difference is I have Disc/Drum.
Would a week booster make the back brakes lock up first? That doesn't make sense.
And if I read correctly you took the lines off at the master cylinder? Would that create another bubble? It seems to me it's either a wheel cylinder or it still needs to be bled more. Could be a bad master cylinder, could be in the proportioning valve.
I know from experience that bad wheel cylinders will make drums lock up easy. If it where me I would inspect your shoe travel vs each side if one is moving more than the other that could indicate a bad hose. And double check your bleeding. Did you bench bleed the master cylinder? If it's been setting for months with no fluid it probably won't hurt to bleed it.
sounds like the proportioning valve or master is connected wrong. since you had it apart I would start there. If you drained the master while doing the work you may need to bleed it then the front brakes again.
The place to start is jack the car up on jack stands. Get someone else to apply the brakes while you attempt to turn each wheel by hand.
Brake lines were not taken off or empty during the time I was doing new bushings and ball joints. I did suck the master out and re fill with fresh fluid after I noticed the brakes weren’t working like they did. After that is when I bleed the brakes. The next day is when I cracked the lines on the master loose. Now that I think about it the air I saw when loosening the line on the master could have been because the first line I cracked it loose I didn’t have any pressure on the pedal because I wasn’t sure it would come loose. I retightened it and the. Had pressure on the second time I cracked it loose. The second line I had pressure on the pedals hen I initaly loosened it. The front wheels would turn by hand when brakes were depressed before adjusting the shoes. Afterwards they would not. I did not check how the rear wheels turned by hand. How would the distribution block play into this? Isnt it only to split fluid for front wheels and give a warning light if you loose pressure on either the front or rear lines? I did think about that and am going to ground out the wire to make sure that the wiring to it works properly. Then I will check shoe travel and rebleed then compare travel again and test drive.
Thanks
When you have uneven pressure between front and back, you risk activating the rod in the distribution block. You are imitating a M/C failure. That is what they are designed to do. It is just doing it's job.
Clues in color, click to expand
Thank
This is a toughie
but you supplied some great clues;
The hard pedal seems to indicate that the hydraulics are OK, keyword "seems"
The halfway down tells me it could be a slack-adjuster adjustment problem
The rear lock-up seems to confirm this
But the statement about having adjusted the front shoes already is a bit of a puzzler
So I'm gonna guess that the front wheel cylinders are running out of piston travel, and hitting a mechanical stop, before pushing the shoes out, or just not moving far enough in the first place. The latter could be because the pistons inside the master are not hydraulically linked,and the front system is actually waiting for the rear to link up mechanically. Thus,it is operating in failure mode.
I suggest to watch the compensating ports one in each reservoir, while a helper slowly applies the brake-pedal,holds it when it gets hard, and then slowly releases it back to the start....ALL the way.. You should see the fluid roiling at the beginning of the application, and a more roiling at the very end, as the fluid returns;watch out for a geyser at the end . If there is any air in the system it will cause the fluid to return in a hurry, and the geyser is the proof of it. I have seen the geyser hit the hood, so protect your paint accordingly, and make sure your helper knows to stop when you yell STOP !!!!!!!! There must be roilings or geysers to prove the C-ports are open. Without compensation, there might not be enough fluid moving out to the Wheel Cylinders to affect meaningful brake action.
Ok so assuming the ports are both open,or that you have mechanically opened them; then I recommend to bench-bleed the M/C, to fill the inter-piston area with fluid. Sometimes/usually, you can get away with doing this on the car. But in your case,you may have to lower the front of the M/C , lower than the rear.
That's all I got
I think I have it all set. The master cylinder was leaking a little bit when I pulled it off the booster. That must be where the air came from. Also someone was in there before and the aluminum spacer plate was upside down and backwards and got cracked. I think because when they tried to put it on right the plastic piece that holds the air filter didn’t have the cutouts for the retainer screw and tab. The rear shoes needed to be adjusted up a little too. It still doesn’t lock up the front right. I am going to try to bleed it again but I think it’s the adjustment is a little loose. I left it this way because there is some runout in the drum. Anyone make a decent drum or should I get these turned if there’s meat on them.
Thanks again for all of your help guys.
