Performance slant six cams
Slant 6 Engines
  1. my68barracuda
    my68barracuda Well-Known Member
    923
    571
    Dec 6, 2009
    Indianapolis IN
    Local Time:
    2:33 AM
    Hughes Engines is releasing a series of performance slant six cams.
    They also have OS valves in the stock slant stem diameter and length.
    Hughes Engines
    • Like Like x 1
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      56,357
      25275
      Jun 7, 2010
      Georgia
      Local Time:
      2:33 AM
      I wish they'd hurry up.
      • Agree Agree x 2
      • Naplm00
        Naplm00 Well-Known Member
        135
        31
        May 20, 2019
        Bay
        Local Time:
        11:33 PM
        is the "whiplash" grind for low end ? i cant read cam profiles
      • my68barracuda
        923
        571
        Dec 6, 2009
        Indianapolis IN
        Local Time:
        2:33 AM
        Yes, the 212 / 206 duration at .050 will have the torque and hp
        peaks lower on the rpm scale.
        Generally, the larger the duration the higher peak torque and peak hp occur on the rpm scale. And the larger those actual values will .
        • Like Like x 1
        • /6 Matt
          /6 Matt 30 Degrees Crooked
          2,426
          129
          Jan 19, 2010
          Lincolnton, NC
          Local Time:
          2:33 AM
          Why do all of the listed LSA have a +4?
        • RustyRatRod
          56,357
          25275
          Jun 7, 2010
          Georgia
          Local Time:
          2:33 AM
          That's the intake center line they are suppose to install at. in other words, if one has an LSA of 108, int would install at 4* +, or 104. Get it?
          • Agree Agree x 1
          • my68barracuda
            923
            571
            Dec 6, 2009
            Indianapolis IN
            Local Time:
            2:33 AM
            And then most slant six racers would move the Intake Center Line 2 to 4 additional degrees forward to get it to 102 to 100.
            Advancing the cam brings the power in earlier.
            • Agree Agree x 1
            • RustyRatRod
              56,357
              25275
              Jun 7, 2010
              Georgia
              Local Time:
              2:33 AM
              Well, yes.......but in my case I won't. Mine is going to end up in the 10.5:1 static compression territory, so I don't need any extra advance. I DO want it to run on pump gas. lol
              • Like Like x 1
